Marcus Desaul
11-27-2003, 09:11 AM
Last night I burned a CD from MP3s on my computer. Switched them to CDA files so a normal CD could recognize them, but when I put the CD into the 8, the system didn't recognize it and spit it back out.
Anyone have this happen to them and if so...did you find a way to make it work?
KC_RX-8
11-27-2003, 09:33 AM
i had that same problem with mine.... it either spit it out of if you changed tracks, it took FOREVER!!!
solution: burn your cd's slower.... use 2X if you have to but every cd i've burnt after that has worked perfectly!!
hope that helps. good luck!
brothervoodoo
11-27-2003, 02:55 PM
Can't say I've had a problem with burning .cda tracks specfically for CD Players. I have a Plexwriter and it burns fine at 8x. Maybe you haven't fully finalized the session, and some older cd players might have a hard time reading? I remember back in the day that slowing the burning process used to help in some applications. Good luck.
