View Full Version : is there anywhere in alabama that can install a pettit s/c or mazsport turbo kit?
chaseevans72089
08-19-2008, 01:59 AM
I live in Alabama and im wanting to get either the mazsport turbo kit or the pettit s/c but they both are located 10 hours away in florida. Does anybody know a place in Alabama or georga or anywhere closer than 10 hours away that can install them? please help... and yes i did search
tajabaho1
08-19-2008, 02:39 AM
uhhh.........no....
chickenwafer
08-19-2008, 03:02 AM
Contact Charles R Hill (on this forum) of Paradox Performance. He has tools and will travel.
tajabaho1
08-19-2008, 03:07 AM
^ the question is.....will Ray survive the KKK?
he told me deep down he's jewish :D
chaseevans72089
08-19-2008, 03:44 AM
ok thanks.. so he would come down here and do the install for me? how hard is the greddy kit to install? im sure i could do it im just not good with the computer part? the greddy kit says it comes with a emanage. does it just plug up and flash the cpu and then im ready to go or what? fill me in on what i need as far as setting the cpu up after the install
chickenwafer
08-19-2008, 02:29 PM
I would highly suggest doing some more research before turbo/supercharging your 8.
Not to be harsh, but FI is something you shouldn't take lightly. You can very easily blow your motor.
The GReddy includes the E-Manage Ultimate, it's a piggyback computer that is basically a glorified liar box to the factory PCM. It does not work like the AccessPORT or flash your computer. It requires tuning, and lots of it, by a tuner that knows rotaries and what they are doing. The AP is a much better route for power and reliability.
olddragger
08-19-2008, 07:00 PM
yes fi on this car is not a plug and play--not being harsh either man, but really --tis a fickle little beast and if you dont have comprehensive knowledge/support it could be frustrating for ya. you can do it but it is work.
olddragger
pdxhak
08-19-2008, 07:09 PM
Call Pettit and Mazsport to see if they recommend anyone in your area. If they say no then consider shipping your car to them or scheduling time with Charles for the install.
mysql
08-19-2008, 07:11 PM
FI isn't fickle. You just need a solid tune, the results are repeatable and performance will be solid without deviation.
If your hardware is crap, then your results will not be consistent. Same goes for the tune.
The only catch with FI is that you have to be mindful for hardware failures. Oil leaks, coolant leaks, vacuum hoses cracking, things getting loose. Any of which can result with much more serious results than if you were NA.
Cattywampus
08-19-2008, 10:35 PM
Tune is the key. Everything else is simple maintenance. If you choose to go FI you should already be prepared to want to check everything. The Greddy kit is easy to install. The pain is getting the manifold and the turbo on. Once that is done its simple as connecting pipes. Get rid of the emanage and get the Cobb AP from mazdamaniac. For a beginner is the best option.
chaseevans72089
08-20-2008, 12:33 AM
thanks.. i stayed up all night researching and i fully undersand the access port now and that is my def. choice. and i think im going with the esmirell kit.. and i familier with FI but i didnt know about the rotary.. this is my first rotary.. so i know i could install the kit but my question was about the ecu of the 8. Im not used to all this computer shit now days.. but after reading all of Mazda maniacs post he has really made me understand the ups and downs on tuning the FI rotary
chickenwafer
08-20-2008, 02:27 AM
Using the AP on the Esmeril kit is difficult because that kit is a blow-through MAF setup, meaning you will max out of the MAF sensor quickly.
mattrotary34
08-21-2008, 03:59 PM
definately not appreciated.....
but theyre still here lol
which can be scaryat times
and yes i can help you with the install as well after we do that local meet thing we were talking about before
olddragger
08-25-2008, 10:08 PM
if this is your 1st rotory(it was mine also) remember you are adding fi to a engine with a 270 degree flame front (watch the cooling) and a 10/1 compression ratio. i would highly recommend a water meth kit with the install for many reasons.
once sorted out the fi rotory can be a very dependable engine. do your due diligence.
it is a fickle beast as the engine become more complex and i guarantee you will not just add a fi system and leave it alone:).
you will need to upgrade cooling unless you live in a cool climate.
olddragger
morkusyambo
08-29-2008, 03:46 PM
I allready have the pettit kit on my car and live in Enterprise. If you want I will drive up to help with your install.
Jedi54
08-29-2008, 04:35 PM
here ya go:
http://i32.photobucket.com/albums/d37/Jedi54/Misc/CRHBeacon.jpg
Jedi54
08-29-2008, 05:00 PM
I figured this thread had gone on long enough without the famous CRH light. :)
morkusyambo
08-29-2008, 05:05 PM
This is the first time I have seen it. But then I had the benefit of getting to know Ray before I realized he had a cult following.
Jedi54
08-29-2008, 05:06 PM
^^^ does that mean we have to wear hoodies and make a secret handshake?
morkusyambo
08-29-2008, 05:13 PM
I think wearing underoos with a logo would suffice.
Razz1
08-29-2008, 08:36 PM
Very constructive comments from Jedi the post whore!
Jedi54
08-30-2008, 01:01 AM
says the guy who keeps following me around calling me a post whore (and at the same time boosting his own post count)
C'mon Glenn, at least post something useful from time to time.
