ABS / DSC light removal
Old Aug 13, 2008 | 03:07 AM
DY8's Avatar
DY8
Hi,
Have done a search but could not find a definitive answer. Having just swapped the suspension out (for the 3rd time ) my ABS and DSC lights have illuminated on the dash. I have checked all the wiring and it is ok, so I am guessing this is down to the current stance where the rear is 2" higher than the fron (not got around to adjusting them yet, it won't be staying like that!)
Would these lights clear with a simple ECU reset ? (disconnecting the battery for 20minutes) or would they need to be cleared at a mazda dealer?
Cheers!
Jimmy
Old Aug 13, 2008 | 10:25 AM
Aseras's Avatar
turn the steering wheel all the way to the left and to the right a few times.
Old Aug 13, 2008 | 10:29 AM
Socket7's Avatar
ಠ_ಠ
Probably just need to start the car, turn the wheel from lock to lock, let it warm up, then turn the car off and start it again. Lights should go away. This happens whenever you disconnect the battery.
Old Aug 13, 2008 | 10:30 AM
Ryan2008's Avatar
Registered Paratrooper
+1. After disconnecting the battery, the computer needs a refresh on the car. Turning the steering wheel back and forth accomplishes this.
Old Aug 13, 2008 | 11:07 AM
DY8's Avatar
DY8
thanks for the responses but sadly it's not that
the "slippy car" sign is permamently illuminated rather than flashing as is the ABS light, it's down to me either disconneting the abs connectors at the rear or due to the abnormal ride height after fitting the new suspension (2" higher at the rear at a guess!)
RevMeHarder
Jun 1, 2026 02:30 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
stickmantijuana
Sep 4, 2015 10:31 PM
