Stiffness In Stering Wheel
Old Aug 11, 2008 | 09:58 AM
bmccarthy's Avatar
H,
My steering wheel has seemed to get a lot stiffer reticently. It's almost a jerky stiffness. Can anyone tell me what it is?
Thanks,
Old Aug 11, 2008 | 12:00 PM
Socket7's Avatar
ಠ_ಠ
Your R2 unit has a bad motivator....
But seriously, it's hard to tell you anything without any details about your car and when the problem occurs. Could be anything from a bad power steering connector to a bad computer, to a small animal caught up in your steering column.
Old Aug 11, 2008 | 12:38 PM
bmccarthy's Avatar
Thanks for the reply,
It's when I turn left or right. Just after the beginning of the turn does it get tight. I really have to pull. Certain area's on the steering wheel are different from others
Old Aug 13, 2008 | 12:27 AM
climacus's Avatar
Just do a search in the tech forum using the keyword "power steering". Chances are your EPS connector is loose.
Old Aug 18, 2008 | 04:56 PM
shodan's Avatar
Mine behaves same.
Guys in mazda service have no idea what is it. No alarm codes what so ever.
They say it might be connectors under air filter box.
I cleaned those connectors under filter and on steering rack - no effect.
They don't belive in my cleaning skills so i had to go again tomorrow.
theblinkof
Oct 4, 2023 05:24 PM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
