Overheating???
Old Aug 6, 2008 | 03:14 PM
TonyCP's Avatar
Overheating???
i have an auto 04 bought it used so i dont know how well the air condition ever worked but it seems as if my air condition is not cooling enough but the air is blowing good. when its hot outside and i have my air condition my car rattles but only when its hot out. also sometimes when i come to a stop and once again its hot outside my car will just shut off and i have a lil hard time starting but i turn off the AC and rev up the engine and its back to normal...and in case you were wondering yes i did already get the new engine DOES ANYONE KNOW WAT MIGHT BE DOING THIS CUZ ACCORDING TO THE DEALER EVERYTHING WORKS PERFECTLY FINE ON MY CAR and im getting tired of dealing with them
Old Aug 6, 2008 | 06:24 PM
04RX8man's Avatar
Rotary Powered Countryboy
personally sounds like a new engine is on its way again....should not shut down at stop lights with a/c on....take ti to dealer and have them do a compression test on it
Old Aug 6, 2008 | 10:05 PM
Use heavier oil than 5w20 garbage, say, at least 5w30.
Change all plugs and coils.
If it still like that, bring it to dealership said u "did the proper maintenance already" show them the receipt of coils and plugs and oils u brought and tell them to test the engine for compression.
Old Aug 6, 2008 | 11:38 PM
Outkast187's Avatar
x2
Ask em if the 09 models do this as well.
Old Aug 7, 2008 | 12:04 AM
TonyCP's Avatar
wat kind of oil you using on ur 8?
Old Aug 7, 2008 | 01:40 AM
hakuna matata!
rough idle.. stalls.. hard starts.. all signs of bad motor.
Old Aug 7, 2008 | 01:47 AM
TonyCP's Avatar
wat do u recommend?
Old Aug 7, 2008 | 02:14 AM
hakuna matata!
Originally Posted by TonyCP
wat do u recommend?
convince the dealer (or mazda na) to run a compression test on that bad boy
Old Aug 7, 2008 | 10:18 PM
you could have a vaccum leak. Go to your local forum, find your local meet.
all your Questions will be answered.
The cabin is too hot from the tranny and engine for the A'C to compensate. Known fact.
Old Aug 7, 2008 | 10:21 PM
wat do u recommend?
I strongly recommend you to use that poor little "Search" button up top for your questions.
Luiss7
54
Aug 20, 2019 08:56 AM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
tommy26Germany
Sep 29, 2015 10:33 AM
iwannarun
Sep 6, 2015 01:37 PM
