NW RX-8 Forum Serving WA, OR, ID, AK
New, to me, Transmission in-bound
Old Aug 1, 2008 | 11:12 AM
kristopher_d's Avatar
Drive Master
Talking New, to me, Transmission in-bound
Found a transmission that doesn't grind and have agreed on a price. Tidying up details then it will be on it's way.
So no more babying the transmission on the drives. I'll be back to late-trailing-braking and using the gear I want, instead of the one that requires the least shifting.
I haven't driven a proper 8 or 9 10ths in soooooo long. I can hardly wait.
If I can find a new contract in the next couple of weeks, I'll order up a flywheel and clutch assembly too.
Old Aug 1, 2008 | 12:01 PM
dondo's Avatar
100% baller (finally!)
awesome!
are you changing the gearing like you mentioned before?
Old Aug 1, 2008 | 12:29 PM
fahrfegneugen's Avatar
Nice work, it will take some time getting use to the new one because it won't have the idiosyncrasies of the old one but you will still treat it like the old one.
Old Aug 1, 2008 | 01:03 PM
Drive Master
No, I'm keeping the gearing stock in the inbound unit. I need to get this syncro-less thing out of the way. I'll crack that one open, and if the hard parts are all okay, do the gearing, shift fork, lower shifter bushing, and maybe some retaining clip mods on that when I rebuild it.
If by idiosyncrasies you mean the requirement of double clutching every up and down shift, I hope you're right.
Old Aug 3, 2008 | 03:20 PM
Shinka-05's Avatar
streetfighter
so your transmission has been going out for quite some time... where you out rallying the roads when the S4 saw you. That ames lake is a great road, as well as old union, good amount of houses though in some parts, gotta be careful Nice S4 huh?
Old Aug 4, 2008 | 11:30 AM
Drive Master
Yes, very nice S4. I was on my way home from a HS reunion in Carnation. I grew up on those roads.
And yes, I've been dealing with Transmission issues for close to a year, and they've been REALLY bad for the last 6 months or so.
Just syncros, though, so not too difficult to compensate for.
Old Aug 8, 2008 | 01:21 PM
Anijo's Avatar
Cone Abuser
Just noticed this thread. Congrats Kris
And it didn't seem to hurt you on Snake Hill
Old Aug 8, 2008 | 02:20 PM
Kris
Did you fix your clutch bracket?
ps: not saying it's the problem...just wondering.....the bracket mod made a huge difference in mine....It got rid of the mystery engagement point problem on the track for me
Old Aug 8, 2008 | 04:08 PM
Drive Master
Dan, Clutch bracket has been reinforced for some time now. I had hoped it would take care of it, but it didn't. The improved pedal feel, and more precise clutch action is nice though.
Anijo, I've actually run that hill considerably faster. Unfortunately, when you can't reliably grab second, and all other gear changes take way too long, you have to compromise and feather some straights and lug a few corner exits. With a proper transmission, there's at least 5 seconds, and maybe even 10 left on that hill. Plus, I'm getting less and less happy with my tires, but that's another thread.
Old Aug 11, 2008 | 12:08 AM
shaunv74's Avatar
Power!!
Glad to hear it Kris. Hope the new trans. is in great shape for you.
Old Aug 22, 2008 | 05:12 PM
Shinka-05's Avatar
streetfighter
sounds like you guys do some runs fairly often. you ppl should hit me up sometime before you go. I can either bring out the s4 or my rx8 :o should be some fun
Old Aug 22, 2008 | 05:47 PM
shaunv74's Avatar
Power!!
www.the-winding-road.com
Check out the site and sign up for an event. Also Kris posts up threads with the next event on this forum each month. You should check it out and come out.
Old Aug 23, 2008 | 03:17 PM
Drive Master
Transmission is in the garage. Anyone have a transmission jack to lend?
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
Mane
Nov 20, 2015 12:16 PM
Von Walker
Sep 13, 2015 03:54 PM
