OEM Break Pads SUCK!
Old Jul 7, 2008 | 12:03 PM
Checksum's Avatar
1 track day and they took 1/16" off my rotors probably more. No scoring or warping but still, thats a lot of rotor wear.
Anyways, whats your recommendation for a good all around pad and where should I get it? I will probably need new rotors too, but I think I can get brembo blanks for a pretty good deal from the shop here. I will try to get pictures later today of the carnage!
Old Jul 7, 2008 | 10:53 PM
ahh.. Obewan, it is a very common problem for newbies on the track to over use their brakes.
Old Jul 7, 2008 | 10:57 PM
AJ's Shinka's Avatar
Enthusiast
Obewan was a Jedi, Checksum a Jedi he is not.
Old Jul 8, 2008 | 12:32 AM
xfukxshytxupx's Avatar
i heard that hawk brakes are pretty good. i just order front and rears for my car. so hopefully i'll be installin them this weekend. i'll let ya kno how i make out
Old Jul 8, 2008 | 12:52 AM
Brettus's Avatar
Boosted Kiwi
so - you have before and after thickness ?
From memory the std thickness is 24mm and min spec. is 22mm ....
Are you below 22mm ?
Old Jul 8, 2008 | 02:10 AM
dothackRAVE's Avatar
<3 Rotary
Uhhh..., previous owner of my car raced the **** out of the RX-8, and he's no slouch around a track. When I replaced the pads, they were still OEMs, and had quite a bit of padding left.
Old Jul 8, 2008 | 08:34 AM
SpIcEz's Avatar
1 inch = 25.4 mm
25.4 mm / 16 = 1.5875 mm
Stock rotors are supposedly 24mm (I read a post a while ago saying someone measured a stock rotor at 23mm)
1.5875 mm eaten in one session means your rotors have at MOST 40% life left after one track day if not 0%.
Doubtfull
Old Jul 8, 2008 | 08:45 AM
fwo's Avatar
fwo
BRAKES
not
BREAKS
Old Jul 8, 2008 | 07:29 PM
nvrfalter's Avatar
tonybob failpants
Originally Posted by fwo
BRAKES
not
BREAKS
thank you. i see this all too often and i want to kill someone
Old Jul 11, 2008 | 09:42 PM
Nubo's Avatar
Lubricious
BRAKES
not
BREAKS
Apparently this particular aspect of illiteracy started early in 2007.
Old Jul 11, 2008 | 10:01 PM
StealthTL's Avatar
Metatron
A simple thread title search on THIS site shows idiocy as far back as 2003......
S
Old Jul 15, 2008 | 01:23 PM
Checksum's Avatar
lol, yeah I know I overuse my brakes as well as fail 7th grade English. Yes the rotors need to be replaced, the pads look good strangely. Part of the problem was the ambient temperature was 103 that day. Asphalt temp was around 160. I think the combination of elements (heat, heavy wheels, heavy break foot) are what did them in. I had never tracked the rx-8 and wasn't expecting it to stop from 120mph quite as fast as it did. My first session is where all the damage probably occurred. After I found out that you don't have to mash on the brakes to get this car to stop it was a lot easier.
Old Jul 15, 2008 | 04:33 PM
Socket7's Avatar
ಠ_ಠ
ahh.. Padawan, it is a very common problem for newbies on the track to over use their brakes.
Fixed it for you.
You took 1/16th off the ROTOR? Dayum. that sucks.
Old Jul 15, 2008 | 07:38 PM
you're in real trouble then because any other hipo brake pad will wear the rotors far worse than the original Mazda pads ...
Old Jul 15, 2008 | 09:08 PM
thecow135's Avatar
hippie not hippo. i like hippos.
Old Jul 15, 2008 | 09:39 PM
hipo = high performance
Old Jul 15, 2008 | 10:14 PM
DOMINION's Avatar
I don't buy Kool-Aid
Should have got some Hawk HP+ pads
vapor2
Jul 9, 2016 07:35 AM
Chapsy
Sep 22, 2015 09:57 AM
neoksk
Sep 21, 2015 12:31 PM
Irvinb16
Sep 11, 2015 10:27 PM
airlive
Sep 7, 2015 08:32 PM
