What is an EVAP emission control system?
Old Jun 23, 2008 | 09:39 AM
seagram14's Avatar
What does EVAP emission do? And what happen if you get a reading of EVAP emission control sytem leak very small?
Old Jun 23, 2008 | 11:21 AM
Socket7's Avatar
ಠ_ಠ
I believe it is gas cap that has gone bad or is not tightened properly. I could be wrong. Evaporative emissions system prevents gasoline vapors from being vented into the atmosphere.
Old Jun 23, 2008 | 11:28 AM
EDZRIDE's Avatar
2005 White GT
^^^ +1
Old Jun 23, 2008 | 11:52 AM
StealthTL's Avatar
Metatron
The system is a canister and carbon filter, but the code is usually triggered by a loose or leaky gascap, as Socket says.
Clean the rim and tighten it down good, it may go away in two or three 'drive cycles'.
S
Old Jun 25, 2008 | 12:53 AM
seagram14's Avatar
Would the small leak from the EVAP would hurt the engine if does not get fix soon, and what else could it be if it is not your gas cap?
Old Jun 25, 2008 | 01:01 AM
gregs's Avatar
Pull My Finger
depends on your evap code your getting but if the gas cap doesnt fix it then the next common item that needs replacement is the evap purge valve
Old Jun 25, 2008 | 01:12 AM
seagram14's Avatar
Where is evap purge valve located?
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
pjwermuth
Sep 28, 2015 11:36 PM
Jb4ker96
Sep 27, 2015 10:06 PM
