View Full Version : turbo manifold idea...
neit_jnf
06-22-2008, 06:03 PM
use the front and rear ports for a divided turbo manifold like previous rotaries and use the center port just for the wastegate?
what do you think? too much restriction until the wastegate opens?
Brettus
06-22-2008, 06:11 PM
Interesting idea - what advantage do you see ?
thinking about it some more - it won't work .
dannobre
06-22-2008, 06:37 PM
That would be a huge restriction to the exhaust unless the wastegate was open.....won't work
neit_jnf
06-22-2008, 09:00 PM
well, the center exhaust port is significantly smaller than the other two so at low rpm and load it shouldn't be of much impact to performance except maybe increasing velocity at the other ports (good for spooling)
then, having a divided manifold could be good for better spooling a turbo with a divided exhaust housing and when the center port wastegate opens it controls boost without disrupting the main flow to the turbo...
Brettus
06-22-2008, 10:23 PM
at maximum rpm and boost you are going to be significantly restricting the exhaust - wont work .
chickenwafer
06-23-2008, 12:07 AM
It's still not redirecting flow away from the turbo, that's how a wastegate controls boost. If the wastegate is shut, the exhaust will just exit out of the other port.
It's like putting a wastegate on a single exhaust valve of a dual exhaust valve piston motor. Won't work.
rotarygod
06-23-2008, 09:10 PM
Not going to work.
