Question about switching thermostats?
Old Jun 18, 2008 | 05:54 PM
Vasichko's Avatar
Since the RX8 runs very hot, couldnt I find another thermostat with the same dimensions but one that fully opens at 180 degrees and have no issues?
Old Jun 18, 2008 | 06:38 PM
ken-x8's Avatar
You could probably find one, but I would not recommend doing that. The factory thermostat is selected to hold the engine at an intended design temperature. Putting a lower one in would make it run too cool.
If the standard stat is opening all the way and your car is running hotter than intended, a cooler one won't help - it would open all the way, too.
Ken
Old Jun 18, 2008 | 09:45 PM
Vasichko's Avatar
Ah ok
Old Jun 18, 2008 | 10:23 PM
05rex8's Avatar
sold the 8... :(
If you purchase the cobb accessport from mazdamaniac, it turns the fans on at 180 degrees, thus keeping temps down. Plus a ton of other things it can do.
Old Jun 19, 2008 | 10:22 AM
Easy_E1's Avatar
Stampede! I wish it was that easy of a solution for my overheating issues.
Old Jun 19, 2008 | 10:37 AM
Easy_E1's Avatar
^ I have one of the three ready to go in.
Old Jun 19, 2008 | 10:53 AM
09Factor's Avatar
Original Turbo 'd Auto !!
That's what Michelle said.
thats bad Ray
Old Jun 19, 2008 | 11:06 AM
I've got 1/3, should be aquiring at least 1 other component soon.
Old Jun 19, 2008 | 11:22 AM
Huey52's Avatar
Registered Zoom Zoomer
As others have said, our stock T'stats are higher rated for emissions purposes. Keep in mind that one of the reasons the rotary doesn't get as good fuel efficieincy as a comparable piston engine is its relatively low thermal mass. This is a compromise to keep it warmer. All design is compromise.
Old Jun 19, 2008 | 11:58 AM
09Factor's Avatar
Maybe, Dave, but I still have a credit to decorate my new residence with, right? The move to AZ is accelerated, especially if my latest personal hope pans out.......
Yep, Thought about it on the way to work this morning.
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
MolsonB
Sep 11, 2015 12:24 PM
