electrial engine connectors?
Old Jun 14, 2008 | 10:06 PM
rotarenvy's Avatar
does anyone know of manufactures that make compatible plugs for the rx-8. in particular I looking for the DBW plug male and female to make an extension harness.
Old Jun 15, 2008 | 04:06 PM
rotarenvy's Avatar
yeah there might not be much point in a plug in extension.
I don't like doing mods that can't be easily reversed. soldering also leaves hard points in the loom.
I also realized I could just use weatherpack connectors between the std loom and extension and move the std plug to the end of the extension. no need to find strange plugs that way.
still I'll check denso out first
Old Jun 15, 2008 | 04:14 PM
They usually want to sell them in huge lots....you might be able to get a couple as samples if you are a good bullshitter
Old Jun 18, 2008 | 01:36 AM
rotarenvy's Avatar
thanks GTAW!
you make it look easy. I'll probably give it a go.
vapor2
Nov 3, 2020 03:38 PM
Pelleilee
Sep 29, 2019 10:07 AM
BigKid
Sep 23, 2015 07:46 PM
MolecularConcept
Aug 1, 2015 03:15 PM
ion_four
Jul 30, 2015 09:48 PM
