Help with anti-corrosive coating on replacement OEM brake rotors
Old Jun 1, 2008 | 09:05 PM
Matt RX8's Avatar
I'm replacing my brake rotors with OEM replacement rotors. The rotors were shipped with a thick layer of anti-corrosive coating on them. Looks like a thick silvery paint.
Is it necessary to remove this from the braking surface before installing or can I let the pads scrape the surface clean when bedding them in?
I know that there was also a TSB a while back about this anti-corrosive coating causing the brakes to make a clicking sound under hard cornering.
Any tips on how to remove this coating? I tried paint thinner and carb cleaner but it didn't have much of an effect.
Old Jun 1, 2008 | 10:44 PM
Nubo's Avatar
Lubricious
If it were me I'd take some medium grit sandpaper to them and take off the bulk of it, being careful not to go inside of the "swept area". Or you could take it to a shop that machines brake rotors and have them turned just enough to remove the paint.
As far as the clicking -- search for the TSB, I believe the recommendation there was also to sand off the coating where the wheel mates with the hub, although maybe the coating has been reformulated since then. Make sure to follow the new torque specs in the TSB for the lug nuts.
Old Jun 2, 2008 | 08:00 AM
costello's Avatar
Go to Pep Boys or Autozone and pick up a can of brake cleaner. Spray it on the surface of the rotor and wipe clean. You should always clean that stuff off new rotors prior to installation.
seb16
Sep 15, 2016 12:20 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
BigMikeATL
May 26, 2016 12:31 AM
Kahl
Aug 20, 2015 11:49 PM
dbarber
Jul 25, 2015 01:34 PM
