bad gas mileage
Old Jun 1, 2008 | 10:40 AM
richardl1205's Avatar
bad gas mileage
Im only getting about 200km per tank ! This can't be normal. Any ideas.
Old Jun 1, 2008 | 11:21 AM
burnaby rx-8's Avatar
That is definately not normal. In fact, it's about a third less than you should be getting. Take it to a reputable dealership and have them check it out. If there happens to be something wrong, it should be covered.
Old Jun 1, 2008 | 11:23 AM
Rems31's Avatar
someone's syphoning your gas
Old Jun 1, 2008 | 04:05 PM
Brettus's Avatar
Boosted Kiwi
look inside the intake for oil . If you find any clean it up clean the maf and fit a catch can .
how many miles have you done ?
Old Jun 2, 2008 | 05:43 AM
I only have 23000km and it's impossible that someone is siphoning my gas it's always in my garage.
Old Jun 2, 2008 | 09:49 AM
Rems31's Avatar
sorry i was just being a smart @$$...
but let's go over the most obvious (people here have made these mistakes before so don't feel offended).
1. Are you sure it's set to kms and not miles?
2. Do you fill up the entire tank (or close to it) after driving only 200kms?
Old Jun 2, 2008 | 09:55 AM
dozer's Avatar
on his 3rd rx8
mmmmmmm i just got the new REFLASH it made a noticable difference...
Old Jun 2, 2008 | 03:54 PM
Yes it's set to kms and I always fill it to the top. I did not mention that this was all city driving. Do you think that's it. The dealer seems to think this is the problem. I find that hard to believe.
Old Jun 2, 2008 | 04:20 PM
Brettus's Avatar
Boosted Kiwi
worst i've ever got all city - driving like i stole it - 300km
Something definately not right ......
Old Jun 2, 2008 | 05:46 PM
dying_here's Avatar
200km to the tank?? thats like 30L/100km.... something is definitely wrong.
Old Jun 2, 2008 | 07:43 PM
SpecialBlend's Avatar
For the longest time I have been getting consistently about 250km(in 100% city) to a 50 liter fill......that works out to just under 12 MPG.....the lowest that i think i got was about 200 and that was when i was letting it warm up to normal temp before driving it (big mistake). While this was going on i took it on a road trip and got about 21 mpg on all highway. My car has about 55,000 km on it and just this week i got new spark plugs put in and after that i jumped up to about 16-17MPG with mostly city.
I have only put one tank in since the new spark plugs. I will report back once i put another tank through, probably won't be that long though
Old Jun 3, 2008 | 06:25 AM
nate340's Avatar
on the track i got 160km out of a tank. i usally average 11.5L/100km which is over 400km a tank. do you warm your car up by letting it sit and idle if so that could be the problem.
Old Jun 3, 2008 | 09:20 AM
MIBagentQ's Avatar
replace your O2 sensor. There is a HUGE difference between driving in open loop and closed loop.
Old Jun 3, 2008 | 09:22 AM
The Access Port from MM will cure the pig rich conditions and you will get 2-3 more MPG
Old Jun 3, 2008 | 09:53 AM
dozer's Avatar
on his 3rd rx8
^so will the reflash
Old Jun 3, 2008 | 10:58 AM
TriRx-8's Avatar
TRI RX-8
i typically get 330ish in the city...
I did a road trip from toronto to montreal and got over 460kms and was usually cruising at an average speed of 120-125
Old Jun 9, 2008 | 02:55 PM
I have put another tank through my car since i replaced the spark plugs and i made 310 km on the tank with similar city driving. This works out to about 15 to 16 MPG which is more acceptable than 10-12 in the city. I would suggest that if your car is over 50,000 to get the plugs changed out if poor gas mileage continues(or at least get them checked).
Vedivan1
Sep 18, 2015 12:39 PM
Redheddude222
Sep 14, 2015 02:55 PM
GARCIAC951
Sep 10, 2015 07:17 PM
Tsurugi
Sep 7, 2015 08:27 PM
titaneum_grey
Sep 6, 2015 10:21 PM
