Clear Corners Troubleshooting
Old May 25, 2008 | 09:32 AM
cpo32's Avatar
So I finally got around to purchasing a set of clear corners. I figured I'd do it right so I got a pair of Stealth Bulbs from RX8Strakes. I took the reflectors out and everything seemed to be going very easily. When I put the new bulbs in and put the clear corners on, I tested it out with my blinkers and nothing happened. No light. So I figured I had bad bulbs. Then I put the original bulbs back in, no light again. Then I attached the new wiring harness that came with the clear corners in replace of the old ones. Again, no light. Any ideas as to what could be going wrong. I really don't want to get a ticket for malfunctioning side marker lights
Old May 25, 2008 | 09:52 AM
Shifty Devil's Avatar
First, check the fuse for the circuit.
Second, I haven't had my lamps out but they might require a ground connection through the mounting point instead of a wire. If so, you should be trying them out mounted on the car and not dangling in the air.
Old May 25, 2008 | 10:04 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
This is gonna seem stupid, but you know those don't work off the blinkers right?
Those side markers only work if you have the lights on.
If still no worky, then check the fuse and see if you blew that fuse.
It's not the ground in anyway....it doesn't depend on any ground off the housing on the side markers....you can have them dangling and check them if you like.
Old May 25, 2008 | 11:27 AM
BigWillieStyle's Avatar
Che is my BITCH!!!
LMAO!! Sorry, but I can't help it!! LMAO!!
Old May 25, 2008 | 11:34 AM
Easy_E1's Avatar
Oh lord!
It gives me a warm fuzzy feeling to know that this forum is helping the noobs learn about there cars.
Old May 25, 2008 | 12:31 PM
lilring's Avatar
Finally a MT
hey, if you find out what is wrong. please post up and let me know. i have the same problems with mine.. i have the rx8strakes.com side markers with the led bulbs and they dont work..
Old May 25, 2008 | 12:50 PM
Rems31's Avatar
Mine blink when I keep turning my lights on and off...but I can never make it only blink on one side at a time
Old May 25, 2008 | 03:36 PM
RXwizard's Avatar
RXwizard
Funny stuff. Yeah, the side-markers are just that. They're not supposed to blink. I thought the same thing too when I changed out my clear corners the first time. Figured it out after about 1/2 a sec though.
Old May 25, 2008 | 03:58 PM
digitalSniperX1's Avatar
Can anybody tell me where the "how to vacuum an RX-8" and "how to operate an RX-8 trunk lid" forums are located?
Honestly, the correct answer to the question about side marker lights is "who gives a $hit" or....nevermind
Old May 25, 2008 | 04:01 PM
Spinning Sushi's Avatar
I <3 Sushi
OoOOOo... My clear corners blink when I hit the turn signal.
http://www.youtube.com/watch?v=er5pIQKFAMA
Old May 25, 2008 | 09:45 PM
HockeyRX-8's Avatar
TNC
That's really cool.
Old May 25, 2008 | 10:44 PM
cpo32's Avatar
Good call on the fuse. I changed it out today and everything worked fine. I'm just wondering how long my side markers haven't been working for
Old May 26, 2008 | 08:47 AM
Ericok's Avatar
Rotary Wanker
Clear corners come with a wiring harness?
Old May 26, 2008 | 11:16 AM
cpo32's Avatar
Mine did...I got them from Japan Parts as part of the Group Buy a couple of weeks ago
Old May 26, 2008 | 11:48 AM
Greenblurr93's Avatar
Sotally Tober
they come with a little pigtail that you dont need to use...
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
duworm
Oct 1, 2015 04:57 PM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
