Quick DTA / Igntion Coil question.
Old May 23, 2008 | 06:03 PM
PhillipM's Avatar
Hi, after a little trouble with the Microtech unit we're temporarily on a DTAfast ECU.
Now, we've everything wired in but I'm having a little think about the coils, I can't remember if they run inverted trigger or not?
The DTAfast is setup as standard to go to infinate resistance on the trigger to signal 'off', but I'm pretty sure the Microtech was setup the other way around, with continuity being the 'off' signal?
The only problem is, if I connect it up wrong and crank her up, either the coils or the ECU will get fried!
Old May 24, 2008 | 06:48 AM
PhillipM's Avatar
The DTA ECU only has one setting for amplified coils, on or off, so I'm guessing that wants to be on?
Old Jul 3, 2008 | 02:25 PM
PhillipM's Avatar
215whp, in case anyone was interested.
Estimated flywheel was 258bhp.
Old Jul 3, 2008 | 02:36 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
what problems did you have with the Microtech?
N/A? What type of dyno?
Old Jul 3, 2008 | 03:19 PM
PhillipM's Avatar
Some dodgy sensor pickup flicking readings all over, went back but the replacement was going to take too long to arrive, so we switched to DTA in roder to have it done ready for an event.
Yes, it's still N/A, dyno was a Sun Diagnostics model, from other standard cars running there I'd guess it was about 4-5% over-reading, so I'd figure it at about 245bhp real
Old Jul 3, 2008 | 03:23 PM
tdiddy's Avatar
Nice numbers N/A!
Was it the Eccentric Shaft Position Sensor?
Old Jul 3, 2008 | 03:25 PM
PhillipM's Avatar
No, it was the temperature sensors - flitting all over the place, checked all the wiring it, tried known good sensors, no dice, so the dyno operator (whom we bought it off) send it straight back, sounded like he'd had that before, or heard of it.
Did do a quick run on his dyno actually up to 6k, to make sure the engine/installation was OK (had quite a lot of oil in rotors and stock manifold - which was concerning), where it made 166bhp at the wheels, that was on a Rototest hub dyno. Went somewhere else for a full map due to time issues.
Old Jul 3, 2008 | 03:32 PM
PhillipM's Avatar
Oh, quick note for anyone considering DTA - we should have a solution that can run the motor on the auxilary ports within a week.
Old Jul 3, 2008 | 03:57 PM
tdiddy's Avatar
Water temperature or Air Intake Temperature?
My Air Intake Temperature sensor reading from the OBDII port is way off with the Interceptor-X. Mazsport sells one that plugs into the Interceptor tho.
Thats cool. Can it be programmed to open them whenever you hit boost?
Old Jul 3, 2008 | 04:45 PM
PhillipM's Avatar
Water and Air intake temps.
Yes, you can program them for RPM or MAP, from an analogue or an input signal, or combination of each, or by what you had for breakfast that particular day.
Think we may go back on a hub dyno for a power run just to get a perfect ATW figure when we have chance, the high-angle CV joints tend to sap power when strapped down, they get very warm on rollers.
Old Jul 3, 2008 | 05:12 PM
MazdaManiac's Avatar
Is this an S80?
Old Jul 4, 2008 | 07:34 AM
PhillipM's Avatar
Yes, S80 Pro.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
Rupanrx
Sep 4, 2015 06:44 AM
