djkrazy
05-18-2008, 12:58 PM
I got from axis 275 (in the rear) that cause some rubbing on the itrees when i hit bumps and oither things on the road. I was told that one of the ways to avoid the problem is to roll the fender. another way is to get a stiffer suspension for the car ...... the question is if anyone else had that problem and which would be better.
nuke0907
05-18-2008, 08:15 PM
why would you put 195mm. wide tires on an RX8? :lol:
kersh4w
05-18-2008, 08:35 PM
how would you have problems with 195s?
stock is 225 and most people run 245s....
Mazurfer
05-18-2008, 08:40 PM
WTF???????????????? Give us all the dimensions of your tires and wheels.
This should be interesting.
Macius8
05-18-2008, 08:50 PM
I dont think they make the tires stated in his sig in the size he mentioned. Think he meant 295s
Mazurfer
05-18-2008, 08:53 PM
Ahhhhhh................I didn't notice that.
Yeah..................probably a typo!
LionZoo
05-18-2008, 08:55 PM
I got from axis 195 (in the rear) that cause some rubbing on the itrees when i hit bumps and oither things on the road. I was told that one of the ways to avoid the problem is to roll the fender. another way is to get a stiffer suspension for the car ...... the question is if anyone else had that problem and which would be better.
Going to a stiffer suspension is a band aid solution. If your tires rub, going to a stiffer suspension won't cure rubbing as there will always be instances when you're into the bumpstops. It might decrease the frequency of rubbing, but the problem will still be there.
Mazurfer
05-18-2008, 08:58 PM
^+1 on that.
Assuming you are 295........you need to roll the fenders.
djkrazy
05-19-2008, 10:30 AM
sorry about the confusion and the typo in the thread ... my rear spec are 18 X 9.5 and 275 .... 18 X 8.5 and 245 in the front but there is no problems in the front
Mazurfer
05-20-2008, 01:42 PM
I'm 255 wide in the back right now on 18 x 9.0 and I have some minor rubbing with my 1/2 inch lowering on RB springs but it's so minor I haven't had to do anything.....YET. A lot will depend on your offset........mine is a little strange at +38mm.
I can see how you would rub at 275(offset depending) and I think rolling is still your best option.
NgoRX8
05-20-2008, 01:51 PM
the most important thing is offset.
i assume your offset isn't so low that rolling will alleviate the problem. if so, roll it, and have the tab where the bumper bolts up to the fender either flared or shaved.
TeamRX8
05-20-2008, 02:23 PM
1. buy the proper wheels
2. roll fenders
3. stiffen suspension
4. drink bleach
NoPistonZ
05-20-2008, 10:20 PM
You don't necessarily have to roll the fender from well to well. I just need to roll a 9" lip center top outwards. I'm on rear 18x9.5 +35 with 275/35/18. on Tein S-Techs.....Depends on your offset, tires and drop.
I just drank bleach.
djkrazy
05-21-2008, 11:05 AM
I am going to roll over the weekend .... i think .... i just hope that I dont crack the paint
4 years to Supercharge
05-21-2008, 12:13 PM
I just saw tirerack sells a fender rolling tool now.
05-21-2008, 12:17 PM
Here is a DIY on rolling the fenders. http://www.mazda6tech.com/index.php?option=com_content&task=view&id=17&Itemid=1
Hmmm heat gun to help minimize cracking of the paint. Would that actually help that much? :confused:
