Potential problem
Old May 11, 2008 | 07:29 PM
xsnipersgox's Avatar
One Shot One Kill
Potential problem
I just recently changed my trailing plugs and installed the mazdatrix coil wires. the wires were installed to where the shorter ones ended up on the back rotor and the longer ones ended up on the front rotor. This will be changed out this tuesday when i get my new coils.
i swear i haven't hear this distinct clicking sound before i did these installs. can anyone listen to the videoclip of engine idle and tell me if i have any problem? thanks.
fyi : i also have noticed that i lost the 2 rubber gaskets on the intake box on the bottom, and cannot locate them. however my fan is still spinning.
http://www.youtube.com/watch?v=wiI7-iXQj48
concerns:
1) clicking noise
2) mucho vibration of engine.
Old May 11, 2008 | 07:35 PM
G3tR3DDY2GR3DDY's Avatar
yep that would be a plug wire not making contact, take a wire off and start the car tell me what happens :P
also explains the vibration. Make sure the wires are in the right spot, on the plug all the way, and connected to the coil all the way. That clicking is the spark going out the end of the plug wire and popping. Now you know how fast your spark plugs fire :P
Old May 11, 2008 | 09:31 PM
One Shot One Kill
lol, dude thanks man. i rushed out and checked it
1) the Trailing plug i replaced was not properly torqued down (they were loose)
2) one of the wire was not securely attached to the plugs and another was not very secure on the coil
so i went ahead and swapped the wire to the proper locations and torqued down the spark plugs, now its idling much much better, thanks.
Old May 11, 2008 | 11:16 PM
np!
now you learned something
Old May 12, 2008 | 06:55 PM
One Shot One Kill
great, when i replaced my coil today, i over torqued and snapped one of the studs. getreddy u got one of these for sale?
i need either 99791 1 screw thing, or i need the whole assembly, lastly.. can i still drive with the coil sitting semi on the plate?. seems to idle alrite.
Old May 13, 2008 | 09:21 PM
Yes you can drive. you have two of three. Get the bolt from the dealer.
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Vedivan1
Sep 18, 2015 12:39 PM
