Cabin Temperature/Thermostat Issue
Old Apr 20, 2008 | 08:30 AM
SleeplessFantasy's Avatar
I think maybe there is a mechanical issue with the thermostat for the cabin, but im not sure. During the winter/spring change over (when i need heat or not) i noticed that when i wanted heat, it would not come on until i turned the **** all the way to hot, then it was getting WAY to hot, so i would bring it back :::::one single notch::::: and it would start to get really cold, though the **** was clearly still in the hot side.
Any ideas????
Old Apr 20, 2008 | 08:38 AM
secret8gent's Avatar
the enemy in the mirror
hcu? (heating control unit)
search for some good info on how to test it.
Old Apr 20, 2008 | 10:17 AM
It is a common fault..the part to fix it ( **** assembly) is covered by the bumper to bumper warranty...otherwise it is about $200 I think
Mine is doing it too...I'm going to pull the unit out and see if I can fix it though before I replace it...
Old Apr 20, 2008 | 10:26 AM
Bumble_Bee's Avatar
"Autobots Roll-Out..!"
Without having the A/C nor Heater on..Does it include the warm air that seems to be coming from under the dash (primarily the passenger side).. ??I already know about the cup holders area being normal...
Old Apr 20, 2008 | 10:48 AM
Try having a turbo stuffed under the passenger side floor......My wife likes it...keeps her feet toasty and warm
Old Apr 21, 2008 | 08:24 PM
There are no abnormal heat sources. I have no mods or anything anywhere. Its a stock car. I know the heater core is fine, because i do get heat, and lots of it, when i get the **** to work.
Old Apr 21, 2008 | 10:43 PM
teknics's Avatar
Certified Mazda Tech
Its is your A/C control head most likely, the temperature control **** is known to go bad, will be covered under warranty. Its an exchange unit which means it will have to be ordered and youll have to go back to have the units swapped.
kevin.
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
Irvinb16
Sep 11, 2015 10:27 PM
tgaffner
Sep 7, 2015 08:49 PM
