BFGoodrich G-Force T/A KDW-2 or Toyo T1R
Old Apr 15, 2008 | 01:35 PM
Macius8's Avatar
Which one would you pick in terms of performance (grip, sidewall flex, etc) and comfort (road noise, bad road absorption, etc)
Also how would you rate Dunlop SP Sport 9000
Many thanks
Old Apr 15, 2008 | 08:03 PM
sonicspeed17's Avatar
I can't speak for the other tires but I can for the kdw's. as far as performance goes these are the best street tire I have ever had the wet traction was the same as dry traction, the noise was a little high, but you get used to it, now you may say that there has to be a negative side. ant that would be the treadlife a set of these lasted me 9,000 miles and they were down to the threads, I did autocross a few times but still, so if you don't mind replacing them every few months or just use for racing then I would defentally recommend the kdws
Old Apr 15, 2008 | 08:08 PM
Rxceler8's Avatar
I have the G Force in 265/30-19...Best Tires I have thus far..Better than Ventus K104s and Toyo's..
Old Apr 15, 2008 | 08:10 PM
JGR4444's Avatar
GR
if the choices are between those get the KDW's... i work at discount tire so i know a thing or two... and if you want some advice get the g force sports... same performance less noise... do not go toyo or dunlop.. especially dunlop
and your ride is going to be real hard with a 30 offset... just letting you know
Old Apr 15, 2008 | 08:30 PM
Macius8's Avatar
great thanks guys,
30 on a 19 in rim and 275 width gives the best ratio to stock diamter
Old Apr 16, 2008 | 02:46 PM
Nemesis8's Avatar
Bigus Rotus
The T1R's are quieter than the KDW's if that matters to you.
Old Apr 16, 2008 | 03:09 PM
ODDDOOD's Avatar
The DOOD abides.
Thats unfortunate!!! Did you rotate every 3,000 miles?
I had a set of 245/40/18 on a stock setup and got about 28k miles out of them. I rotated about 5k miles and no AutoX or "driving events" though. I'm sure that will steal some life out of 'em.
I did notice superior wet and dry handling, with little to no break away. Any slide was extremely predictable...except for one in near freezing conditions in Maryland...yikes. All-Season tires FTW in freezing temps.
As for the noise...yeah, they make lots. Kinda gets old, but you will get used to it.
I will probably get the KDW2 once my SPTs run out.
Good Luck
Old Apr 16, 2008 | 03:46 PM
Klone's Avatar
I have the KDW-2s on my WRX and the T1Rs on my Elise and I don't think you can go wrong with either. The T1Rs do seem quieter and as for grip, both grip well on both cars, while the two cars are not comparable I drive both hard and have not run into any sketchy situations I did not induce myself. I like the look of the KDW-2s, but the T1Rs are not bad. It would probably come down to a choice of brand. I did have more of a problem getting the T1Rs balanced, I had to go to a place with road force balancing to get rid of high speed wobble.
Old Apr 16, 2008 | 04:39 PM
Macius8's Avatar
Great thanks, KDW-2s it is,
Is 275/30/19 or 275/35/19 more appropriate on a 10" wide rim.
Ideally the first is closer to the stock tire height.
Old Apr 17, 2008 | 12:56 PM
Ajax's Avatar
I've had the KDW2's on my car for 35,000 miles now. Last time it was at the dealer, he called them slicks. Now, they still have SOME tread left, but yea, they need to be replaced.
I'm not sure if I want to buy another set. As they wear, they do get very loud.
Old Apr 17, 2008 | 01:12 PM
pdxhak's Avatar
Official Post Whore
Lots of varying opinions on the KDW2's. I have them and will not buy them again. They are loud and the sidewall is soft. It feels like I'm rolling into the corners :rant They are great in the rain when the weather is above 50*.
Originally Posted by Macius8
Many thanks
275/30/19 kdw2's will not fit up front. I assume you are planning to run a staggered setup. Do not go wider than 245 up front with the kdw2 tires.
Old Apr 17, 2008 | 02:18 PM
canaryrx8's Avatar
have the kdw 2's on mine, had the t1r's previously, definitely like the bfg's better
Old Apr 17, 2008 | 06:45 PM
BlueRenesis82's Avatar
Registered Tracker
BFG for the win.
Old Apr 17, 2008 | 10:44 PM
Macius8's Avatar
I thought they would. I've seen several people running these sizes all around on this forum with little or no problems. I will not mind a fender roll if it comes to that. I do not want to go staggered.
I did hear about the soft sidewall issues. What other tires would you recommend under 300, must be a street tire.
Old Apr 17, 2008 | 10:51 PM
pdxhak's Avatar
Official Post Whore
A search on this tire should have brought up this thread I started on liner rub. I'm running 255/35/19 front and back and have a slight liner rub. Unfortunately fender modifications will not help you.
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/wheel-well-liner-rub-141153/
Old Apr 17, 2008 | 11:04 PM
Macius8's Avatar
I did search but didn't see a point clicking on a "wheel well liner rub" thread
With the 275/30/19 tires the overall diameter will still be smaller than the 255/35/19's, by more than half an inch. The effect of overall diameter due to tire width can be adjusted by changing the profile. But now I know that 275/35/19 is out of the question, thanks.
Old Apr 17, 2008 | 11:15 PM
pdxhak's Avatar
Official Post Whore
I must have entered the wrong numbers. You are right about the overall diameter being smaller
Old Apr 17, 2008 | 11:25 PM
Macius8's Avatar
Cool Looks I'll go with the BF's unless I find something I like.
Thanks for all the help.
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
wayloco
Sep 1, 2015 09:03 PM
RXeckless
Aug 16, 2015 12:51 PM
