Picture on inside door?
Old Apr 10, 2008 | 08:53 AM
psonoda's Avatar
Less Weight = Better RX8
Does anyone have a picture of the RX8 front door with the speaker out and the window rolled down?
I am starting my project and wanted to double check before buying my subwoofers.
Yes I said subwoofers.
Old Apr 10, 2008 | 09:27 AM
canaryrx8's Avatar
search is your friend, there's a few folks that have pictures on here, just have to look for them....yes...I said look for them
Old Apr 10, 2008 | 03:50 PM
psonoda's Avatar
Funny.
I did search but after about an hour I gave up. I did find great pictures without the window rolled up. I guess it would have been faster to remove the door panel.
Anyway, I purchased the subs. I will figure out how to make them fit or I will use them in another vehicle.
Old Apr 10, 2008 | 05:59 PM
Socket7's Avatar
ಠ_ಠ
You didn't read the audio install guide sticky did you?
Safe mounting depth for speakers in the front door is located in the first post of Speaker size, harnesses, kits, etc: Audio install reference . There are links to the photos you're looking for too.
Last edited by Socket7; Apr 10, 2008 at 06:03 PM. Reason: I don't think the photos are there, I'm sure they are.
Old Apr 10, 2008 | 06:52 PM
psonoda's Avatar
Actually I did. It did mention speaker depths around 3 inches but is also said that more depth could be had if the magnet cleared the window when it was down.
It has great pictures except I did not see one with the speaker taken out and the window down. The speaker I am planning to use has a neo motor structure that is quite small (about 3" in diameter) so if the window only goes into the opening 2-3 inches, it should clear.
Anyway, I am getting the speakers tomorrow and I will see what will actually fit in the door.
Old Apr 10, 2008 | 07:01 PM
psonoda's Avatar
Here is a picture of the subwoofer. I am planning to use 4 of these.
One in each door and to replace the 6 x 9 in the rear deck. Each woofer only weighs 5.88 lbs but has about a inch of linear travel.
Old Apr 10, 2008 | 09:33 PM
Currin's Avatar
CopB8
you puting bigger subs in the door! damn my doors shakes already with the ones its got.
Old Apr 10, 2008 | 09:49 PM
canaryrx8's Avatar
I've got 8's in my door now, factory size is 9". We built out a spacer but only because of the mods we did to my door panel, I don't have everything handy or I'd post pics for you. (it's on another pc...doh!)
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
vapor2
Sep 19, 2015 05:33 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
czr
Sep 13, 2015 11:37 AM
