Injection system malfunction and Misfire cylinder 2
Old Mar 31, 2008 | 07:02 PM
Piston-less's Avatar
I have a 2004 Mazda Rx-8 with around 43,000 miles on it. For the past couple days it has been acting strange under acceleration and stuttering when the throttle is applied. Also the car is having a hard time maintaining speed via the cruise control. The car seems to have a lack of power and the problem gets worse the further up you go in the rpm range. The title of this thread is the codes I got when I pulled the codes from the OBDII port. If anyone has any suggestions please let me know. Thanks in advance for your help.
Old Mar 31, 2008 | 07:04 PM
expo1's Avatar
He's as bad as Can
Check the spark plugs, do you still have the plugs from day one??
Old Mar 31, 2008 | 08:18 PM
No, I purchased the vehicle used, so I am not sure if the original ones are still in the vehicle. Will the spark plugs cause it to throw and injection code?? I figured that would be more ignition as I thought it was the spark plugs till I saw that.
Old Apr 5, 2008 | 02:33 AM
in this order.
plugs
coils
wires
also make sure the plugs are tight, and the wires are tight on the plugs.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Stubbs
Sep 27, 2015 04:06 PM
