Help neede: Pin out of a Bose Rx-8 amp?
Old Mar 23, 2008 | 02:26 AM
DerHONK's Avatar
Hi,
I have a Bose amplifier, received from a RX-8 crash car, and unfortunately all wires are cut direct behind the plugs. Everything I've found on the web and in this forum didn't match the pin out of the amp I have. Maybe someone here can help me out:
Is it really form a RX-8?
Is anyone familiar with the pin out?
How can I test it which cable is for what (I'm no electronic specialist)
Sorry for my bad english, it's not my native language.
Attached Thumbnails Help neede: Pin out of a Bose Rx-8 amp?-bose_end.jpg   Help neede: Pin out of a Bose Rx-8 amp?-stecker_bose.gif
Old Mar 23, 2008 | 10:31 AM
jstkilntim's Avatar
resU deretsigeR
It definitely doesn't match the 2004 information that I used for my car. The plugs are the same, the amp looks the same, but the wire colors are definitely not. It looks like it is from a car w/ out audio pilot. If you want to try to test it I would try this.....It should get you connected.
My Plug is marked different, but I will use your markings for simplicity. I have completely rewired my amp w/ RCA plugs etc. so unless I have a misprint on the drawing I made for it, I know it is correct.
ReiheA
12- left front out -
11- left front out +
10- right front out -
9- right front out +
8- left rear out -
7- left rear out +
6- right rear out -
5- right rear out +
4- (normally audio pilot microphone)
3- (normally audio pilot microphone)
2- blank
1- blank
ReiheB
12- blank
11- not sure
10- right front in +
9- right front in -
8- left front in +
7- left front in 1
6- right rear in +
5- right rear in -
4- left rear in +
3- left rear in -
2- not sure (but suspected to be remote switched B+)
1- not sure
Small plug
A- ground
B- center speaker out +
C- blank
D- blank
E- blank
F- blank
G- center speaker out -
H- B+
Please let me know it this works.
jst
Old Mar 23, 2008 | 01:01 PM
DerHONK's Avatar
Hi jstkilntim!
many thanks for your quick reply!
I will try out immediately your suggestions.
I'll keep you informed with the results.
Thanks again!
Old Mar 23, 2008 | 01:55 PM
firebirdude's Avatar
User and Abuser
Looks like the RX8 Bose amp to me.
Old Mar 24, 2008 | 05:47 AM
DerHONK's Avatar
After setting up all wires with no results, it looks like that the amp is defect
Thanks again for the setup!
Old Mar 24, 2008 | 06:46 AM
jstkilntim's Avatar
resU deretsigeR
Did you supply B+ to ReiheB-2?
Old Nov 28, 2010 | 02:22 PM
Riley's Avatar
hiya, i have a 2004 8 with bose, my question is can i connect to the input to the amp in the boot in order to craete an aux and will that work all the speakers? sorry if this is in the wrong spot!!! new to all this! cheers!
Old Nov 28, 2010 | 02:41 PM
Riley's Avatar
just found this site, has full wiring for bose amp http://www.audizine.com/forum/showth...57858-Bose-amp
Old Jun 20, 2011 | 11:10 AM
DubbsLuvs8s's Avatar
Didn't want to start another thread, but long story short I've narrowed my problems down to the Bose amp either being fried or something that I don't want to deal with.
Going by this pin-out, I could bypass the amp all together by just shunting the speakers ins and outs, right? I realize there won't be a center speaker out, which is fine for me, I just wanted to know if there were any other unforeseeable consequences. Thanks
Old Jun 20, 2011 | 07:03 PM
User and Abuser
That won't work. Not enough power output from the stock Bose headunit to push the speakers without the amp. Additionally, the front woofers are 1/2 ohm. I don't think the headunit can handle a load like that, regardless of power output.
Old Oct 25, 2020 | 09:23 AM
sira1978's Avatar
Help need : Connector for Bose Rx8 amp
Hi,
I m looking for any lead for a supplier to get both connectors of the Bose 9 speaker amp F152 66 920.
Thanks in advance,
Shiran F
Old Oct 25, 2020 | 09:51 AM
sira1978's Avatar
MI Help need : Connector for Bose Rx8 amp
Hi,
I bought Bose 9 speaker amp and speakers from crash car, but without connectors. any leads to find 2 x connectors for the amp?
Thanks in advance,
Shiran
eXentric
13
Jul 31, 2021 04:29 PM
rAgOs
Series II Interior, Audio, and Electronics
Oct 2, 2016 06:07 PM
808rx82005
15
Nov 8, 2010 11:14 AM
Tigerfootball
Mar 24, 2009 07:11 PM
RNE515
Jul 8, 2007 11:10 PM
