Wheel well liner rub
Old Mar 21, 2008 | 10:43 PM
pdxhak's Avatar
Official Post Whore
Anyone with front wheels that rub the wheel liner? I'm not rubbing on the fenders but definitely both front wheel liners. Anyone mod their liners?
I know not all tires are the same so there could be other tires that are the "same" size that do not rub. Anyone know of a web site with measurements for the actual tire and not just a general measurement for the size of a tire?
In the first picture the wheel is fully locked. I can not get my index finger between the tire and the liner but they are not touching.
The second picture they may be touching. If they are not then maybe a sheet of paper will slide through.
Tires: BFGoodrich KDW NT 255/35
Wheels: 19x8.5
Offset: +40
Rub mark highlighted
Wheel on top of the rub mark
Old Mar 21, 2008 | 10:58 PM
great thread; I'm curious to see if anyone has been able to mod the lining to prevent this.
Old Mar 21, 2008 | 11:11 PM
pdxhak's Avatar
Official Post Whore
Thanks man. I know there a few others here that are running 255/35/19 front and back like me. I believe someone is running 265 up front but I do not recall if they have 18" or 19" wheels. Also I'm thinking the guys running 18x9.5 275 or 285 tires up front has run into this.
Old Mar 22, 2008 | 06:07 AM
Spinning Sushi's Avatar
I <3 Sushi
Roll them.
Old Mar 22, 2008 | 06:23 AM
pdxhak's Avatar
Official Post Whore
Originally Posted by Renesis SE3P
Roll them.
Roll the wheel well liners
There is no fender rub so no need to roll.
I <3 Sushi
That's what I meant.
Old Mar 22, 2008 | 07:18 AM
chrism's Avatar
Misfit Moderator TnC
im thinking it has to be the tires....i had the kdw's and they seemed chunkier than other tires of the same size
Old Mar 22, 2008 | 11:16 AM
pdxhak's Avatar
Official Post Whore
I'm thinking it is KDWs as well. They do not really have radius on the edges of the tires and they could be wider than other 255/35 tires. I was hoping someone would post up a site that has the actual measurements per brand of tire and not just a general measurement.
Also looking for anyone that has modded their liner.
Is it a bad idea to remove it?
Old Mar 22, 2008 | 11:21 AM
chrism's Avatar
you really dont want rocks or water getting in there or sitting in there.......
Old Mar 22, 2008 | 11:47 AM
chris: saw your post in the will it fit thread about Kel. Looks like I'm gonna roll the dice and order some 255/35 toyos. (I was already leaning towards toyo)
They'll be mounted to some SUPER SEXY 19x9 +40.
Old Mar 22, 2008 | 11:53 AM
pdxhak's Avatar
Official Post Whore
Good point. Maybe I can sand down where it is rubbing since it is raised. If I have time today, I will pull the liner before doing anything.
Old Mar 22, 2008 | 11:54 AM
What! you wore out the Toyo 245s already?
Old Mar 22, 2008 | 11:58 AM
maybe....
great idea! just sand it down a bit, reinstall and see if you can clear. If not, rinse and repeat.
Old Mar 22, 2008 | 12:02 PM
It's interesting that they rub...I have 18X10.5 +43 offset..and they don't rub there...must be the tire profile??
There is no room to sand the area...you might be able to warm it up with a heat gun and bend it out of the way...
Old Mar 22, 2008 | 12:10 PM
dan: what size tires you running?
pdxhak's Avatar
Official Post Whore
Do you know what is behind the wheel liner where I highlighted above? I do not so just wondering why you think it can not be sanded. It is raised and no other part of the liner touches the tire.
What is interesting, per tire calculators, 255/35/19 is the closest you can get to the OE 225/45/18 setup.
Old Mar 22, 2008 | 12:18 PM
Those have 265-35-18 Neovas..but the 275-35-18 Azenis..and the 275-35-18 NT01's fit as well???
Old Mar 22, 2008 | 06:36 PM
NgoRX8's Avatar
gotta be the tires
Old Mar 22, 2008 | 09:11 PM
pdxhak's Avatar
Official Post Whore
Definitely what I was thinking. Too busy today to check behind the liner so maybe later in the week.
Old Mar 22, 2008 | 10:03 PM
The liner is heat molded plastic...it is about as thick as a pop bottle...you can't sand it
You however can heat mold it with a heat gun and get it out of the way...there is lots of room there...only problem is the plastic has a memory..and tends to relax back to it's original form
Old Mar 22, 2008 | 11:01 PM
pdxhak's Avatar
Official Post Whore
I did not know that about the plastic liner. I have a heat gun with a 700* and 1000* setting so I may give this a try. I am concerned that it may look like crap when I'm done. Obviously I need to take it slow and be patient. I use my heat quite a bit when I build/rebuild golf clubs. Anyone need some club work done let me know
Old Apr 6, 2008 | 01:39 PM
pdxhak's Avatar
Official Post Whore
Today I put a strip of duct tape over the rub mark and colored it with a sharpie and then took a drive around the block. Definitely some minor rub still occurring. Unfortunately smoothing out the raised area with heat gun is not going to work because behind the liner is either piece of the fender or door. Looks like I will be looking for new tires.
Old Apr 7, 2008 | 01:39 AM
c41250n's Avatar
cause i think you should be using 255/30/19 instead!
Old Apr 7, 2008 | 01:55 AM
pdxhak's Avatar
Official Post Whore
The specs are too off. Again I think it has to do with kdw2 tires being wider than other 255 tires.
