Odd Electrical Problem -- won't start
Old Mar 20, 2008 | 06:24 PM
laferle's Avatar
My '04 AT has been garaged this winter, and not surprisingly, it wouldn't start today and appeared to have a dead battery. However, it wouldn't jump with the battery connected, so I bought a replacement battery and tried it out. The starter still won't turn, though there's a little bit of activity under the hood.
The following components work just fine:
- wipers
- headlights
- instrument cluster
- taillights
The following are completely dead:
- starter/ignition
- power windows / locks
- audio system
Can anyone point me to a fuse that might be blown, or some kind of explanation for why a random smattering of devices work perfectly?
Thanks for any insight you guys can offer!
Old Mar 20, 2008 | 06:45 PM
Brettus's Avatar
Boosted Kiwi
does sound like a fuse - you know where the fuses are right ?
Old Mar 20, 2008 | 09:50 PM
laferle's Avatar
Yeah, none of the fuses either in the cabin or under the hood (at least the translucent ones) appear to be blown, and there doesn't seem to be an obvious subsystem that would tie the non-functioning things together if it were one of the bigger ones... unless I'm missing something?
Old Mar 20, 2008 | 09:53 PM
Brettus's Avatar
Boosted Kiwi
did you actually pull out the fuses ? They sometimes blow in such a way you can't see just looking at them while still installed .....
Old Mar 20, 2008 | 09:56 PM
StealthTL's Avatar
Metatron
Check to see if the trunk light is working.
Does it light?
S
Old Mar 20, 2008 | 11:28 PM
laferle's Avatar
I pulled out any fuses I thought might be relevant and they looked to be OK.
Stealth, the trunk light does not come on when the trunk is opened, nor do any dome lights.
Thanks...
Old Mar 20, 2008 | 11:34 PM
StealthTL's Avatar
Metatron
Trunk light is a real clue - those systems AND the trunk light (room fuse) are all powered from the 30 Amp fuse, marked BTN and it's the third one from the top left in the front fusebox.
Pull it and check it....
S
Old Mar 21, 2008 | 12:02 AM
laferle's Avatar
Stealth,
Thanks for the response. The BTN fuse looks ok, and I swapped in a different one to see if it had any effect, just to be safe, and I got the same result. Any other ideas?
Thanks.
Old Mar 21, 2008 | 12:05 AM
Brettus's Avatar
Boosted Kiwi
Check the relay for that circuit - swap it over with another one the same if there is one .....
Old Mar 21, 2008 | 12:22 AM
laferle's Avatar
Brettus --
How do I identify the relay in question? Some are pretty obscurely identified -- I tried swapping the IGNITION and ST relays to no avail.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
