Down to two tire choices...
Old Mar 10, 2008 | 11:53 AM
Phish806's Avatar
Its definately time for some new tires and i have narrowed it down to the Nitto Invo or the Falken RT-615's. It would be used for daily driving (mainly the weekends) and about three or four track days in the year. Which ones do you guys think would be the better choice? both are about the same price and just lookin to get a years worth out of them. Thanks for the help and let me know your thoughts.
Old Mar 10, 2008 | 01:14 PM
Tim Tim Tim's Avatar
auto suckkssssss
rt615's. I love those tires.
Old Mar 10, 2008 | 02:20 PM
LionZoo's Avatar
road warrior
Why does two specifically? They're not comparable tires and have very different characteristics. The main question is, would you rather have a civil daily drive and sacrifice some trackday performance or have a louder daily drive and shorter tire life for a somewhat better trackday experience.
Old Mar 10, 2008 | 02:41 PM
nuke0907's Avatar
Never Blend In
Ditto. those 2 choices don't even compare. you could probably get a better tire somewhat in the middle that would have good characteristics of both those.
Old Mar 10, 2008 | 03:05 PM
Phish806's Avatar
Its manily a question if the RT-615 would work well as a daily driver and if they would last a whole spring/summer/fall withought needing replaced. If not then i was thinking the invo for a better street tire that will still grip and last a little longer.
Old Mar 10, 2008 | 03:10 PM
dshiznit1489's Avatar
Formerly Polak Graphics
Bridgestone Potenza RE050 Pole Positions FTMFW
Old Mar 10, 2008 | 04:42 PM
Spin9k's Avatar
Momentum Keeps Me Going
RT-615s will easily last a yr, and esp. if you only do a few (5-8) track days a year. First I got the 235/40/18 RT-615s and they are great on stock wheels, on the road and on the track. They are really a quick change artist... really good DD tire on the street, gui track tire under track heat conditions. I still have those as a barely legal tread depth set on the stock wheels and store my car on them, they still pass state inspection.
I think the Nitto Invo may not be even close to the best tire in it's class your money can buy, and as others have said, better tires at a similar price can be had if that's the grade of tire you're looking for (low end street tire). And they won't hold a candle to the RT-615 for handling.
As a shameless plug, I'm going to have a set of 275/35/18 RT-615s with ~50% tread available shortly, pm me if you're interested for particulars.
Old Mar 10, 2008 | 06:02 PM
Phish806's Avatar
Well the decision has been made and i just purchased the rt-615s ... thanks for the help fellas
Old Mar 10, 2008 | 07:44 PM
HouRx8's Avatar
Spin9k
Did you run the 275's on the stock rim?? If so, how'd you like them? I'm thinking of 255's for autocross (vs 245's).
Old Mar 10, 2008 | 08:33 PM
Spin9k's Avatar
Originally Posted by HouRx8
Spin9k
No, on Enkei 9.5"x18". I don't think I'd go over 235 on the 8" stockers. I'm a firm believer in giving a tire as wide a wheel support as is reasonably possible, better for the sidewalls to be like this \_/ or |_| rather than like this /__\ otherwise you're pinching the tire, and messing with the contact patch, making for sloppy handling response. For a 255 I'd go with a 9" min or 9.5" rim for sure.
Old Mar 10, 2008 | 09:09 PM
HouRx8's Avatar
thanks for you input, the potential sloppy handling does bother me.
My reasoning for the 255's over 245's was even with the distortion the patch would (this is a guess though) be about the same and save 2lbs (ish) a corner - of course as a newb I probably won't notice the weight! I'll save the expreimentation for later!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
