View Full Version : Gauge & Boost Controller install questions
tdiddy
03-02-2008, 12:24 PM
I am installing my GReddy Profec II Boost controller and my other gauges/wideband. I would prefer to use fuse taps for the power wires. I suck at wiring.
1. The boost controller says to connect the RED wire to a 12V Ignition Power source. Does that mean a Constant or Switched power source?
2. Is either the ACC (7.5 amp) fuse or the CIGAR (15 amp) fuse in the drivers side kick panel a switched power source?
3. Is the AUX PWR (20 amp) fuse in the driver side kick panel a constant power source?
4. Is there fuse in the driver side kick panel that can be used as a power source for when the headlights/running lights are turned on or do I have to use the Cigg light wire for that?
Also, does anyone see any problem with running 3 gauges, a wideband, and a boost controller on the same power source?
StealthTL
03-02-2008, 01:23 PM
1 - Switched.
2 - Both.
3 - No, switched.
4 - No, underhood. (you could use the glovebox light)
S
tdiddy
03-02-2008, 01:56 PM
So where can I tap a 12V constant power source at?
tdiddy
03-02-2008, 01:58 PM
Never mind. Found it in the DIY section. The "ROOM" fuse has constant power. Thanks Stealth!
Kane
03-02-2008, 03:30 PM
Thanks for posting that tdiddy- I need to know too!
tdiddy
03-02-2008, 05:22 PM
Here is how I am going to run my power wires.
Constant Power Source: ROOM Fuse or the Solid Green Wire for the driver side kick panel fuse box.
Switched Power Source: AUX Fuse or the White-Green Wire for the driver side kick panel fuse box.
Headlight Activated Power Source: Cig/Ashtray Light (Yellow w/ Orange stripe)
ChattyRX8
03-02-2008, 09:39 PM
What type of connections are you going to use? Soldering? Wire taps? Wire tees?
If you run gauges in parallel, will it make a notable difference in the brightness of the illumination?
Thanks for posting the colors and locations of the wires, BTW.
tdiddy
03-03-2008, 09:06 AM
I wanted to use Fuse Taps for the Constant 12V and Switched 12V but it doesn't appear that is possible because there is not enuff room in the drivers side kick panel for a fuse tap.
That means I will probably try to use vampire clips (wire taps) on all three power sources. If that doesn't work, I will have to solder everything.
Not sure about the brightness until I can test it out.
staticlag
03-03-2008, 09:41 AM
is the yellow with orange stripe in the kick panel? I gots to wire up my wideband today, don't really feel like running it to the cig light :(
tdiddy
03-03-2008, 11:05 AM
No, the Yellow w/Orange stripe is not in the kick panel. Its the Cigarette/Ashtray light. There isn't anything in the kick panel that is activated when the headlights are activated.
