Air/Fuel..Gauge
Old Mar 2, 2008 | 08:44 AM
nelsonrx8's Avatar
Air/Fuel..Gauge
Anyone know which wire i should tap into ,coming from exhaust
color choose is white,blue and 2 blacks
Old Mar 2, 2008 | 08:54 AM
StealthTL's Avatar
Metatron
The wires from the rear O2 sensor are yellow, red, brown and striped white.....
What are you tapping into?
Old Mar 2, 2008 | 08:58 AM
nelsonrx8's Avatar
ok then im really a mess lol
need to get my air/fuel gauge hooked up......
i was hooking it up too a sensor that is connected to exhaust
Old Mar 2, 2008 | 10:54 PM
TheWulf's Avatar
My 8 looks like a Smurf
didnt your gauges come with wiring diagrams?
Old Mar 3, 2008 | 07:26 AM
nelsonrx8's Avatar
no wiring diagrams
Old Mar 3, 2008 | 08:15 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
I don't think you can "tap" into the OEM sensors to run your gauge. You need an aftermarket Wideband O2 sensor in order to run an AFR gauge.
Old Mar 3, 2008 | 09:00 AM
nelsonrx8's Avatar
directions say connect to O2 sensor switch
Old Mar 3, 2008 | 09:05 AM
CnnmnSchnpps's Avatar
No means yes
which gauge did you get? i believe the front sensor is the wideband (the rear is just there to test for cat efficiency.. not sure if it's possible to use the oem sensor to drive an a/f gauge
Old Mar 3, 2008 | 09:07 AM
nelsonrx8's Avatar
prosport A/F gauge
Old Mar 3, 2008 | 09:12 AM
No means yes
doesn't it come with its own sensor?
Old Mar 3, 2008 | 09:13 AM
nelsonrx8's Avatar
http://prosportgauges.com/digital-ai...tio-gauge.aspx
Old Mar 3, 2008 | 09:15 AM
nelsonrx8's Avatar
This gauge is one of our easiest gauges to install with a 3 wire hook up.
Red-12v power
Blk- Ground
Green-output signal (usually the grey wire) on your stock O2 sensor.
Old Mar 3, 2008 | 09:29 AM
No means yes
the problem is you need to make sure the gauge is compatible with the output the stock o2 sensor produces.. afaik different manufacturers use different electronic circuits to "drive" the sensor. pray someone more knowledgeable chimes in
Old Mar 3, 2008 | 09:34 AM
nelsonrx8's Avatar
ive been waiting lol
ill leave it till someone can give me a answer need too put dash back together
Old Mar 3, 2008 | 11:12 AM
staticlag's Avatar
The Professor
For as long as i've heard those type of gauges don't work with the rx8's sensor output.
I think you would need a full standalone like this:
http://www.innovatemotorsports.com/x...cfc270852a05b0
or
http://www.autometer.com/cat_gaugede...earch&gid=3604
or
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
Old Mar 3, 2008 | 11:28 AM
nelsonrx8's Avatar
that would suck since i got it from a forum member
Old Mar 3, 2008 | 11:30 AM
staticlag's Avatar
The Professor
https://www.rx8club.com/showthread.p...air+fuel+gauge
Old Jun 30, 2008 | 11:59 AM
marcux's Avatar
Yeay Boosted!
The front is a wideband. You'll need to connect it to the back. I know this is a bit late, But I ran into this problem already. you want to connect it to the Blue wire.
the 2 blacks are just grounds.
Old Jun 30, 2008 | 01:11 PM
No means yes
umm why would you ever connect a wbo2 gauge to a narrowband sensor?
Old Jul 1, 2008 | 07:09 AM
marcux's Avatar
Yeay Boosted!
Because his gauge is a Narrowband Gauge connecting to the rear Narrowband sensor.. you could figure it out any way you want.. He asked which of the 4 wires to use. Where did you see him saying he had a wide band gauge? Most gauges out are narrowband...
Old Jul 1, 2008 | 08:47 AM
No means yes
my bad.. i assumed if someone were installing an o2 gauge they would want one that's actually useful
