vacuum hose not in place
Old Feb 16, 2008 | 01:13 AM
imrtommy's Avatar
Need Rotary Engine!!!
i need help with putting the vacuum hose from the valve to the pcm under the throttle body. please help. from top to bottum on the intake manifold, what order does the yellow and red valve vacuum hoses go to? thank you for all the help.
Old Feb 16, 2008 | 03:54 AM
DOMINION's Avatar
I don't buy Kool-Aid
You should send Charles R. Hill or MazdaManiac, they can help you out BIG time!
-Gil
Old Feb 16, 2008 | 09:56 AM
I thought one of them for SSV and the other is the last connecting port(forgot the exact name)
Old Feb 16, 2008 | 10:31 AM
imrtommy's Avatar
thanks for the help guys. let me explain my problems as of now. i think i got the hoses in the right place. yellow circle in the bottum for pcm. red cir in the middle for pcm. airpump at the top for pcm. the symtoms are occuring like this. 1k to 5k same power from what i can tell. 5k to 7k major power loss. 8k is like vtec or nitrious kicking in. anyone ran into this problem before? checked all plug wires, they seem to be tight and in place.
Old Feb 16, 2008 | 11:00 AM
Might have the SSV and VDI hoses mixed up...
Top one on the Manifold is the air pump solenoid..that you don't have anymore
Middle one is the SSV... to yellow circled
Bottom one is the VDI to red circled
JimmyBlack
273
Feb 10, 2020 10:23 PM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Evan Gray
Nov 24, 2015 01:00 AM
Hunterkelley24
Oct 1, 2015 09:11 AM
