spark plug analysis please?
Old Feb 10, 2008 | 07:11 PM
CnnmnSchnpps's Avatar
No means yes
Just changed out my plugs today and would appreciate some comments These were supposed to have been changed by the dealer when I bought the car a year ago, but looking at them that doesn't seem to likely. Anyway, thoughts?
Old Feb 10, 2008 | 07:13 PM
Looks like you need a new set...they are worn...and kinda crapped out.
The color is OK...not oil fouled or anything....just had it!
Might need a few more WOT burns on your car though
Old Feb 10, 2008 | 07:18 PM
No means yes
yep i put in a new set. the slightly worn electrodes seem to indicate they were in too long, and the baked on crap could be ash from the oil injection?
Old Feb 10, 2008 | 07:36 PM
DarkBrew's Avatar
Extraordinary Engineering
^^ Yup, oil injection leaves those deposits. As stated before, your engine needs a little bit more redline time. As for the dealer... well that's what you get trusting the dealer to work on your car.
Does anyone using the Sohn OMP adaptor and 2 stroke oil have a picture of their plugs?
Old Feb 10, 2008 | 07:58 PM
No means yes
Yeah I learned that lesson pretty quick that's why I am doing all the maint. myself now... Slightly off topic, but coils and plugs really cleaned up alot of the hesitation issues I've been having. Car feels great again
Old Feb 10, 2008 | 08:05 PM
Might want to check the coils if you have more than 50K on the car...they seem to crap out as well. Plug wires tend to be a bit suspect at that mileage as well
Old Feb 10, 2008 | 08:06 PM
wcs's Avatar
wcs
no agenda
I wouldn't trust my Mazda dealer in Orangeville to wipe my ***.
My plugs looked the same after 35,000km maybe a bit more on the white side. Any ideas on that? Running hot?
Anyways I would expect to change my plugs every 30,000km at least.
Old Feb 10, 2008 | 08:35 PM
DarkBrew's Avatar
Stop the NOZ!!
Old Feb 10, 2008 | 08:54 PM
No means yes
Yeah I changed the coils as well. Thanks for the tips guys
Old Feb 10, 2008 | 09:03 PM
Not as bad as mine, but I premix like a bitch (8-12oz), so maybe thats why
now I cut it down to 4 oz, hell I might do the adapter thing soon. then we'll see what happens.
Old Feb 10, 2008 | 09:08 PM
No means yes
I'd think that premix would have less to do with the ash buildup than the dirty *** engine oil... I premix 7oz, but only started very recently. I'll keep checking the plugs and see what they look like...
On another note, if I ever find the person who last installed plugs in my car I'll buy them a beer. After reading some horror stories on here I was afraid they were going to be impossible to get out, but they ended up coming out quite easily. Anti-seize FTMFW!
Old Feb 10, 2008 | 09:13 PM
mysql101's Avatar
I just snapped a photo of my old plugs. But I'm not so sure how fair a comparison they are since:
1. I don't use OEM plugs. I use the colder RX-7 ones.
2. I'm turbocharged. And I run it hard.
3. I change my plugs once a year.
4. I run the Sohn adaptor with 2 stroke oil.
5. I use FP and LC additives.
Anyway, here it is. It's hard to tell from the photo, but it's solid black, or light color. They don't look grungy like the OP's plugs.
Old Feb 10, 2008 | 09:22 PM
mysql101's Avatar
better pic
No means yes
Solid black = carbon deposits?
Old Feb 10, 2008 | 10:42 PM
staticlag's Avatar
The Professor
solid black = too cold
Old Feb 10, 2008 | 10:44 PM
staticlag's Avatar
The Professor
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
Old Feb 10, 2008 | 11:05 PM
Originally Posted by mysql101
better pic
that looks kinda like mine, I have a little brown-ish stuff, but mostly black. and It was OEM 7 heat range plugs.
Im using 2 steps colder plugs now. After 10 K miles, Im gonna pull it out to look at it. I expect it to be a lot worst than stock heat range.
but it pulls harder than stock tho.
Then Im gonna use the 6 heat range plugs again.
Old Feb 11, 2008 | 07:15 AM
mysql101's Avatar
too cold would make sense. Most of the time a turbo car isn't going to be driven in boost.
Old Feb 11, 2008 | 10:20 PM
downshift 8's Avatar
quick question do 2008 spark plugs fit the 04?
Old Feb 11, 2008 | 11:07 PM
We have the same engine.
You tell me the answer.
Old Feb 11, 2008 | 11:33 PM
DarkBrew's Avatar
better pic
If you ignore the plug range then it looks like you have a lot less of the deposits from oil so typical on our plugs
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
iphil
Sep 21, 2015 10:49 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
