BOSE System Speaker Failure
Old Jan 30, 2008 | 03:44 PM
Insignia's Avatar
My front Bose speakers both are distorting really bad, and I think its because I listen to my music too loud. My fault I know. Can I replace JUST the front component speakers and retain the rest of the BOSE system?
If I am correct I would chose a set of components that I like and amp them correct? Or how else could I do this? Also have OEM Nav but I understand that is controlled through the deck.
Old Jan 30, 2008 | 03:59 PM
Yes, you can replace them. I did so when I 'upgraded' my bose system. Take a look at the Infinity Kappa Perfects. sound AMAZING.
No need for an additional amp, might as well take advantage of the bose amp
Old Jan 30, 2008 | 04:49 PM
Insignia's Avatar
Did you do a component set or just the coaxial speakers?
Old Jan 30, 2008 | 04:56 PM
hondakilla's Avatar
i have the bose system in my and i was "told" that the bose factory amp wouldnt work with any other speakers cause i was thinking of getting infintys. remember was told by someone who has own audio shop for 15 years.
Old Jan 30, 2008 | 04:59 PM
firebirdude's Avatar
User and Abuser
If you're not planning on adding an aftermarket amp and sub along with the speakers, I'd replace them with new Bose speakers. You're going to lose a TON of low end by swapping out a 9" woofer/subwoofer for a 6.5" coaxil/component set.
Old Jan 30, 2008 | 05:03 PM
I upgraded the front components, rear components, rear 6x9's, and added subs.
Don't take out the Bose door speakers, you'll have one HELL of a time trying to find something that works there.
Old Jan 30, 2008 | 05:08 PM
Socket7's Avatar
ಠ_ಠ
The 9" woofers in the door panels of the bose system run at 0.5 ohms. No aftermarket speaker is going to be capable of handling an impedance like that. The front tweeters have a more standard impedance, so if your tweeters are whats blown, yeah get a set of aftermarkets and drop them in. If the woofers are gone you will need to replace them with OEM speakers, unless you want to wire up a LOC, amp, run cabling to the front of the car, and build some sort of adapter to fit a 6.5" speaker in a 9" hole.
As Jedi said, the rear deck speakers also have a standard impedance of 2-4 ohms, so the infinity kappa 6x9's drop right in and sound great!
Old Jan 30, 2008 | 05:17 PM
Juice's Avatar
I made some poos
I second the Infinity Kappas, they actually have a pretty decent low range (680.7cs and 693.7i). I still need a sub. I have plans for it, but no funds.
Replacing the doors speakers on the bose is going to be a bitch, there is practically nothing out there with a .5 Ohm impedance. You can find pretty much anything else in the bose system to upgrade as they have normal impedances. Its just those 9 inch woofers in the doors that will be the pain in the ***.
Edit: Yeah, what Socket7 said, HAHA
Old Jan 30, 2008 | 05:27 PM
in Jedi you must trust.
Old Jan 30, 2008 | 10:33 PM
No way the force has never been with you.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Jst4fun
Mar 5, 2021 07:16 PM
crimson809
Aug 14, 2016 10:03 PM
Learners_Permit
Sep 27, 2015 07:38 PM
