Holes left behind by the OEM Spoiler
Old Jan 28, 2008 | 10:10 PM
NaarLeven's Avatar
Just some ballpark figures, but how much do you guys think it would cost to fill in the holes on my trunk? (assuming I took off my wing)
Old Jan 28, 2008 | 10:15 PM
G3tR3DDY2GR3DDY's Avatar
just trade with someone who wants a wing... swap trunks. Otherwise i would guess about 200 because you would have to fill and patch and probably respray. Thats a fairly decent price. Could get a little more expensive
Old Jan 28, 2008 | 10:56 PM
200 bucks including paint job.
Old Jan 29, 2008 | 01:35 AM
N rider89's Avatar
^NieL
if you like the mazdaspeed or the racing beat wing, they both use the stock holes.
Old Jan 29, 2008 | 11:59 AM
NaarLeven's Avatar
I know it sounds wild, but could I drive around with the holes for a bit? Or has the OEM Spoiler messed up the paint on the trunk too besides the holes?
Old Jan 29, 2008 | 02:09 PM
2tone's Avatar
The RX-8 is missed
i had the same idea. i'm more worried about water getting into the truck -- may need to put tape on the inside or something. some people have commented on the spoiler leaving some marks; depends on how tight it was on there i think. worth taking a look, maybe you could buff them out if there weren't that bad. no one would really see the holes anyway, at least not while you're driving...
Old Jan 29, 2008 | 11:34 PM
N rider89's Avatar
^NieL
go to like kragen and see if they have some rubber stoppers. also the stock spoiler leaves marks behind that you will have to buff out.
Old Jan 30, 2008 | 01:25 AM
ztbear13's Avatar
My buddy has an sti and he took his wing off it cost him $500 dollars to get the holes filled and the trunk repainted..
Old Jan 30, 2008 | 08:04 AM
Huskyfan23's Avatar
Good luck keeping out the rain....
Old Jan 30, 2008 | 11:55 AM
secret8gent's Avatar
the enemy in the mirror
aren't the holes on the outer side of the water seal?
or are y'all speaking from first hand knowledge?
cause i was pretty sure that is the case.
Old Jan 30, 2008 | 12:56 PM
2tone's Avatar
The RX-8 is missed
^^ don't know, you may be right.
i took of the "mazda" emblem on the trunk and have yet to get the holes filled, and rain doesn't get in that way.
Old Jan 30, 2008 | 01:18 PM
you wont get any rain in because the holes are between the weatherstripping and the outside quarter panel. I would run like that for too long though. They make some rubber plugs that go in the holes that would cover it from rain and be some kind of cheap solution if you didnt care about seeing pieces of rubber all the time
Old Jan 30, 2008 | 05:47 PM
NaarLeven's Avatar
Did it today.
So basically the holes left by the bolts will not let rain in. However on my year(2005) there was some corrosion left behind by the wing which means I definately have to get a repaint.
But on a side note, do not take this off unless you plan on covering it up. There are 3 holes per side, the 2 from the bolts will not let water in however the plastic pieces which hold it on as well WILL let water pool inside the trunk.
I just covered it up with some helicopter tape and it should work until I can get it all painted up.
Threshermal
Apr 15, 2020 09:43 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
yapakanichi
Sep 17, 2015 04:23 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
