cant start car. looking for fuse
Old Jan 20, 2008 | 02:26 PM
Thack's Avatar
In hooking up an alarm off the 12 volt source around the ignition Im pretty sure i blew a fuse. Can someone PLEASE tell me where the fuse for the 12 volt source is. Cannot start the car. The wire is yellow. 2004 rx8
Old Jan 20, 2008 | 02:52 PM
StealthTL's Avatar
Metatron
"....around the ignition......" could you be a bit more vague?
The yellow at the key comes from the 15amp fuse marked IGN. KEY in the engine bay. If you can't find it, please stop attempting to install alarms.....
S
Old Jan 20, 2008 | 03:00 PM
Thack's Avatar
whatever dude. no choice i do this for a living. Just the first time ive done this car. Question wasnt vague cause u answered my question. Greatly appreciate it.
You happen to know where i can get a tach signal. Most cars have one in the diagnostic harness but does this car?
Old Jan 20, 2008 | 04:45 PM
BoosTED's Avatar
You say you do this for a living... but you do not know the wires you are working with?
I understand if it is a starter kill that you putting in.
You mean you are hooking up a remote start?
For an alarm you do not need the tach signal...
Most remote starts do not require the tach signal. I checked the documentation I have but it does not list the tach wire.
Old Jan 21, 2008 | 01:36 PM
Thack's Avatar
lol im hooking up a remote start. I specialize in caar audio however ive started doing remote starts mostly on hondas and toyotas. This is the second mazda ive worked on. The first was a millenia which the same door lock system. as for the tach wire its stated in directechs that the tach wire is the wire opposite the black and black/white at the ignition coils. DEI remotes require a tach signal for this. As far as i know this is standard. I do not see these wires.
delicious_dallan
Jan 17, 2020 09:17 AM
PotatoCannon
Sep 6, 2015 11:48 AM
poppinparker
Aug 10, 2015 09:20 AM
thedragonrotar
Jul 22, 2015 08:46 PM
Kangarhew
Jul 18, 2015 08:27 PM
