Major New Product Announcements: Pre-release info
Old Jan 19, 2008 | 12:05 PM
  #26
Hymee's Avatar
Race Steward
Originally Posted by dannobre
Will this require a hardware change from the Scanalyser?
Upgrade prices available....???
The goal/plan is to use the existing sCANalyser hardware for the interface. Initial developments have sucessfully reflashed using this method, so that is the basis for the next round of work.
Yes - I'll have an upgrade path for those who have supported sCANalyser to date.
Cheers,
Hymee.
Old Jan 19, 2008 | 12:08 PM
  #27
Hymee's Avatar
Race Steward
Originally Posted by Kane
You rule Hymee - Can sCANalyser monitor individual injectors too?
Current versions only report on one pulse width, but essentially sCANalyser can monitor anything that is broadcast on the CAN bus. It might take some more work to get that far - it is just a matter of finding out the "PIDS". Sounds easy - hey? LOL!
Cheers,
Hymee.
Old Jan 19, 2008 | 12:50 PM
  #28
Does this mean you save the curent map on your lap top for emmissions purposes. Then re-install it for smog inspection?
Old Jan 19, 2008 | 01:20 PM
  #29
mark,
i have a couple of templet things that you can make available. send me a email when it settles down....
Old Jan 19, 2008 | 02:52 PM
  #30
Brettus's Avatar
Boosted Kiwi
awesome news - this will be a major coup for you if you can realease it before anyone else
Old Jan 19, 2008 | 03:14 PM
  #31
Hymee's Avatar
Race Steward
Whilst that is entirely possible, I'd advocate that in the right hands, your "current map" would/should be smog legal anyway. It is a very powerful computer - it is just a matter of tuning it correctly for the application.
Cheers,
Hymee.
Old Jan 19, 2008 | 03:15 PM
  #32
Kane's Avatar
Senior Member
How do you plan to manage boost Hymee?
Old Jan 19, 2008 | 03:35 PM
  #33
Hymee's Avatar
Race Steward
I'm not going to give away all the secrets, but lets just say that that computer is more than capable of handling what is required, without resorting to trickery.
Unless I read your question wrongly of course - The other answer is that the driver manages the boost. When you open the throttle enough to lose manifold vacuum, you get boost. When you close the throttle, the boost is bypassed. This is of course in relation to my S/C with the bypass valve.
Or are you talking about electronic control of the blow-off valve or wastegate in a turbo application?
Cheers,
Hymee.
PS - If I go quiet from time to time, it'll be 'cause I'm working on the product. I'm sure there are one or two capable minds here who should be able to chime in with some answers. I reckon I'd probably prefer to get the runs on the board first. But I'll try to provide answers where I can.
Cheers,
Hymee.
Old Jan 19, 2008 | 03:40 PM
  #34
Kane's Avatar
Senior Member
My bad Hymee - I should have been more specific - with MAF; you get total volume of airflow which is cool - but without pressure information. You could calc MAF flow and intake temperature - then deduce the PPO2 I guess...but was curious if a MAP was part of the package.
I was just curious how you were going to handle it.
But I understand secrets too -
Old Jan 19, 2008 | 04:10 PM
  #35
Hymee's Avatar
Race Steward
"Tell them nothing, Hymee!!"
I'll resist that for the purpose of community edumaction. If the computer know precisely what mass of air is entering the engine, then it can calculate the amount of fuel required. The RX-8 doesn't need to calculate mass air flow. It has a very sensitive device on board that tells it - the MAF and it has a integrated air temp sensor. As long as it is calibrated correctly. If the RX-8 doesn't have a MAP (Manifold Absolute Pressure) sensor, then the factory computer can't know anything about one.
Lesson over :D
Cheers,
Hymee.
Old Jan 19, 2008 | 05:03 PM
  #36
rotarenvy's Avatar
Lesson over :D
Cheers,
Hymee.
good work hymee. any info on pricing yet?
how does this work in practice? should the maf then be located after the compressor to correctly measure the air temp? or is the mass flow drawn through at atmospheric the same as the mas flow of the compressed air? and if the latter is true then how is the increase in temperature post compressor accounted for?
Old Jan 19, 2008 | 05:48 PM
  #37
Daemos's Avatar
The more important question is will this work for North American cars?
Old Jan 19, 2008 | 05:51 PM
  #38
^^ Why wouldn't it..same engine, same PCM...different programming is all...
Old Jan 19, 2008 | 06:26 PM
  #39
yes,
as we are his major market...
Old Jan 19, 2008 | 06:56 PM
  #40
Clavius's Avatar
Its all about Style...
Question that I must ask.
Is this Dummy proof? Just curious if I should keep track of this or let the professionals as it where play with this.
Old Jan 19, 2008 | 07:04 PM
  #41
It will be like any other tuning....if you understand what your doing and have good data...you get a good result.
But..."garbage in = garbage out" The system won't be the problem...the geniuses doing the tuning will be
Old Jan 19, 2008 | 09:05 PM
  #42
Daemos's Avatar
Next question is: Can we load pre-made maps (like cobb) and flash the ecu, or will we need to make our own maps for everything?
Old Jan 20, 2008 | 02:03 AM
  #43
kersh4w's Avatar
Hit & Run Magnet
argh. more monies that will need to be spent. but not now unfortunately.
dynos plx.
Old Jan 20, 2008 | 10:19 AM
  #44
olddragger's Avatar
Ok I know i am relatively new to the FI scene and my question may be stupid. But, i would appreciate an answer so maybe I can learn some more.
Once this tuning of our pcm is done--what is keeping the pcm from adjusting via short term fuel trims and long term fuel trims? Does this tuning change the pcm's desire to automatically tune via st and ltft to a 14.1 a/f? if so --without revealing secrets---can you tell me How?
oldsuperchargeddragger
Old Jan 20, 2008 | 10:47 AM
  #45
Kane's Avatar
Senior Member
I am speculating here...
Good question OSCD - but in closed loop - I dunno how you would change it since it uses the narrow band O2...I think.
But like EMU - with the flash you should be able to force it into open loop at will.
If it is like cobb - in the logging interface; you can adjust (say for example idle map) and watch the real time feeds to be sure your STFT is zero...there is a HOW TO article on Cobb's page somewhere that describes how you would do it with their software.
Old Jan 20, 2008 | 10:54 AM
  #46
Spin9k's Avatar
Momentum Keeps Me Going
Given that this tool allows changing parameters within the ECU, you no longer have to "fight" with the ECUs tendencies. IOW you use the tool to change the 'target a/f' then any trim developed will go towards the new (corrected) target.
Old Jan 20, 2008 | 10:59 AM
  #47
Kane's Avatar
Senior Member
Spin9K - You would still be limited by the sensor - I don't think closed loop driving used the wideband one.
Can someone correct me?
Old Jan 20, 2008 | 11:04 AM
  #48
musclecarconvrt's Avatar
Want Need Want Need Want Need.
How much of my savings... er credit ca.... um... money I don't have will this require?
Old Jan 20, 2008 | 11:31 AM
  #49
c41250n's Avatar
nice, keep us updated!
Old Jan 20, 2008 | 11:34 AM
  #50
I would expect the PCM has a defined Lamba reading at each load/rpm point...and in closed loop will try and adjust to that...hence the LT and ST fuel trims.
In open loop...there is no adjustment...so the trims are not changed. You get what your tables say for that Mass air flow
What I'm not sure about...is whether or not the trims are carried forward into the open loop areas or not ....
