View Full Version : leading spark plugs in all 4 spots?
goofydragon
01-17-2008, 01:18 AM
I've read on several other threads that some people have put 4 trailing spark plugs in all 4 spots and haven't had any problems.
My question is, what about putting 4 leading spark plugs in all 4 spots? Does this cause problems? Can they be installed like this for 20-30 miles of driving, just until I can get trailing plugs without any problems.
My car wont' turn over, all the spark plugs are completely fouled and need to be changed. My car is currently parked in a parking lot and I just drive it home before it gets towed away. I just want to know if I can put 4 leading spark plugs as a temporary fix so I can drive my car home.
thanks
dannobre
01-17-2008, 01:26 AM
Leading plugs have a longer reach than the trailing plugs...they will not work
Put in the new leading...and leave the trailing old ones....it should run OK like that.
If it won't start...pull/push start it...
turborx8
01-17-2008, 01:42 AM
DO NOT install 4 leading plugs.
Your better off getting a parking ticket than wrecking your engine.
daisuke
01-17-2008, 01:50 AM
AMEN to that
it's also cheaper to get your car towed
TeamRX8
01-17-2008, 02:08 AM
Like my daddy always said, "If you don't know what you're doing, then don't ..."
DOMINION
01-17-2008, 02:11 AM
+1 dont do it and dont put them dam RX-7 plugs in your RX-8.
goofydragon
01-17-2008, 12:09 PM
thank you for the info. I'll replace just the lead plugs for now, just to drive the car home, then I'll change the trailing plugs once they come in.
thank you again.
nycgps
01-17-2008, 12:18 PM
Put them in only if you want another engine.
DMRH
01-17-2008, 09:39 PM
Wrong heat range too.
Trailing plug point runs a higher pressure compared to the leading hence the difference in plug ratings for "leading - trailing"
7's in the trailing (if you could make them fit) would ping & pop the engine if you asked for 100% throttle.
Guys get away with 9's all round for that reason. The only consequence for 9's in the leading is that they will foul within 1000km of driving as the heat in them is lower allowing carbon deposits to attach themselves to the plug
REgards
dannobre
01-17-2008, 11:20 PM
REgards
By pressure I hope you mean heat/temperature.
DOMINION
01-18-2008, 09:11 AM
Yeah pressure is when you dont pre-load it :lol:
