Rear Bose Amp
Old Jan 12, 2008 | 03:30 PM
dimigon's Avatar
Rear Bose Amp
Just wondering if this is normal. Once you disconnect and re-connect the two rear harnesses connected to the rear stock Bose Amp, does the "DSC Off" along with the squiggly driver, display come on?
If so how do I get it to go away, the DSC Off stays on, I have tried pressing the button, as well pressing and holding it for 7 seconds.
If this is not normal, then I think I might of cut into a wire through the grommet when running my 4ga through it. Any suggestions? Thanks.
Old Jan 12, 2008 | 03:57 PM
Socket7's Avatar
ಠ_ಠ
If you unplugged your battery this is normal behavior. I think you need to turn the steering wheel from lock to lock, or push the brake pedal 20 times, to recalibrate the computer. I forget which does it but your owners manual will tell you, and so can searching.
Old Jan 12, 2008 | 04:00 PM
dimigon's Avatar
Sorry guys for not searching, I actually checked my manual immediately after I had, posted, and corrected this situation, thanks a bunch!
yurcivicsux
192
Sep 12, 2017 10:54 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
