Check Engine light
Old Jan 11, 2008 | 05:11 PM
Dialn24's Avatar
Check Engine light
Got another freaking issue with this car. bought it brand new about a month ago. Has 1K miles on it. Dealer changed the oil and spark plugs this past Monday.
Well, today when I'm leaving work, the check engine light stayed on. Any idea what might cause it to stay on?
Really started to regret this freaking car. A brand new car shouldn't have this issues.
Old Jan 11, 2008 | 05:17 PM
architect's Avatar
Why the regret? You can't blame the spoiler screw up on the car... that's the installer's fault.
Are you sure it's your check engine light and not your TPMS?
Old Jan 11, 2008 | 05:18 PM
4me2's Avatar
gas cap?
Old Jan 11, 2008 | 05:29 PM
Dialn24's Avatar
Because I'm beyond frustrated with dealing with issues on this car at this point.
Lights are jacked up. Dealer tried to adjust to no avail. So, ordering new ones and the leveler or whatever it's called.
and yes, I'm sure it's not the TPMS light. This light just came on today. TPMS has shown up the first day I put the winter tires on the car.
Spoiler issue is part of the car. The installer may have jacked it up, but it's another thing to deal with on a brand new car.
Old Jan 11, 2008 | 05:30 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^+1.............probably gas cap.
Old Jan 11, 2008 | 05:31 PM
Dialn24's Avatar
Originally Posted by 4me2
gas cap?
I'll check that. Thanks for the response to you and the other poster bringing that up.
kersh4w's Avatar
Hit & Run Magnet
3 clicks, no less!
Old Jan 11, 2008 | 05:34 PM
Mazurfer's Avatar
^+1 again!
And this gas cap isn't a for sure thing and I know you pissed off, but if the CEL stays on, and you're near an Autozone, go have them read it and see what the CEL code is..............this way when/if you need to head back to the dealer, you will know what it is before you get there and this will test how good your dealer is. (Don't tell him)
Old Jan 11, 2008 | 05:36 PM
Mazurfer's Avatar
Also.....since the dealer changed the plugs, go make sure all the plug wires are seated correctly. There have been some cars that people have reported that the plug wires have popped off, but you should notice that............as it should run like crap.
Old Jan 11, 2008 | 05:53 PM
Dialn24's Avatar
I didn't notice anything running like crap. I tried the gas cap though and restarted it and let it run, the light stayed on.
Old Jan 11, 2008 | 05:57 PM
4me2's Avatar
maybe give it some time................
Old Jan 11, 2008 | 05:59 PM
BlackRX82006's Avatar
Pedobear approved
This is an old school trick. Take a piece of eletrical tape, and cover up the Check Engine light. It'll go off right away. Out of sight, out of mind
Old Jan 11, 2008 | 06:00 PM
Rootski's Avatar
DGAF
You're getting your headlights leveled? How dumb are you?
Quit bitching and sell it already.
Old Jan 11, 2008 | 06:05 PM
Dialn24's Avatar
THanks
Old Jan 11, 2008 | 06:07 PM
Mazurfer's Avatar
It might actually take a couple of drive cycles right? I'll have to go and SEARCH and see if others reported it took cycles after reseating cap. Also, there is a TSB on the cap as well, but you're a new car right? What year is you car?
Old Jan 11, 2008 | 06:10 PM
Dialn24's Avatar
Old Jan 11, 2008 | 06:13 PM
Dialn24's Avatar
The cap was fully on when I looked at it. I took it off and put it back on. Car is a new 2007
RojoOcho's Avatar
Greensboro's Finest
You can disconnect the battery to clear it if you don't want to wait for the drive cycles. Hold the brake pedal down for a minute after you clear it to use every bit of juice left in the car.
Old Jan 11, 2008 | 06:16 PM
4me2's Avatar
^+1.
Old Jan 11, 2008 | 07:04 PM
fugg's Avatar
Hey, are you talking about turning the lights on, and them flickering for a second before going on full-effect? (For those with the Xenon's)
If so, I was wondering what the hell was up with my lights too...
Old Jan 11, 2008 | 07:10 PM
MP3Guy's Avatar
BTW, my CEL light went on the other day. Checked the gas cap, and sure enough, it was loose. I tightened it up, and refilled the tank, but the light is still on.
Can anyone save me a trip to the dealer??
Old Jan 11, 2008 | 07:32 PM
Dialn24's Avatar
That's not my problem. Mine basically point down pretty much (they go about as far as the fog lights). So, took it to the dealer to get adjusted. Tech adjusted them as high as he could, yet they are still pointing down. It's very difficult to see at night and if it's raining, it's basically impossible.
The dealer is not sure if it's the headlight assemblies themselves that are messed up, or the auto leveler module (or however that works). He is ordering both.
That's what I was referring to. The problem isn't a simple adjustment (unless the guy just did it flat wrong).
Old Jan 11, 2008 | 07:48 PM
Mazurfer's Avatar
You can try to disconnect the negative side of the battery for ten minutes. While it's off, go step on the brake pedal for awhile to bleed anything left in the system and then hook it back up and go for a drive. It might do the trick or it may take two or three drive cycles.
Old Jan 11, 2008 | 07:54 PM
Redpit10's Avatar
G35 Convert
To reset the cel you can take out the bottom 15 amp fuse for a minute (fuse box is under the steering wheel to the left in line with the pedals). I beleive it is the room fuse. This will reset your cel, but your car will drive different (the pcm has to relearn your driving habits) for the first 50-100 miles. If you check engine light comes back on, then the cel is from a bigger problem then your gas cap. Hope that helps a little. It will take a while for your cel to come back on (about 100 miles or so).
Old Jan 11, 2008 | 08:07 PM
chancejat's Avatar
Drive it like u stole it!
take it to autozone so and ask them to read the cel code for you then you know whats wrong.....
