Infinity Basslink Mounting Options
Old Jan 2, 2008 | 05:24 PM
alphamale's Avatar
alphamale
I've seen a few people on here mention that they had an Infinity Basslink mounted in their trunk.
My question is, how exactly does this unit mount? Is it necessary to screw into the floor of the trunk? How hard is it to take it in and out, or is it more or less permanent once it's in there?
I noticed in the literature that there's an option to mount it horizontally? Has anyone here done that?
Old Jan 2, 2008 | 11:52 PM
alphamale's Avatar
alphamale
Old Jan 3, 2008 | 02:57 AM
Wind Dance's Avatar
Central Valley RX8
Sorry i have no idea what your talking about, but just thinking i should let you know, I believe your not suppose to bump every few hours. Please read forum guidelines
Old Jan 3, 2008 | 03:17 AM
https://www.rx8club.com/showthread.p...light=basslink
that took me 19 seconds.. i dont know if that answers your ?. but is it that hard to type basslink into the search bar????
Old Jan 3, 2008 | 03:22 AM
HCTR154's Avatar
I mounted mine, vertically, directly behind the driver's side, rear passenger seat on the upper deck. It was screwed directly to the upper deck, through the carpet.
Later, I installed a rear strut bar and had to remove one of the mounting "legs" in order to gain some clearance with the deck that holds the 6x9 speakers.
After installation, I've had no trouble with it moving around or vibrating loose, but it's still good idea to check it every once in a while. Hope this helps.
Old Jan 3, 2008 | 12:34 PM
alphamale's Avatar
alphamale
Actually, "swoope", I did do that, but I never saw that thread. I don't know why you assumed I never searched, but believe me, I'd much rather find it on my own that interact with people that are so quick to make false accusations and remind me of forum rules.
Thanks for the link anyway.
Old Jan 3, 2008 | 12:40 PM
alphamale's Avatar
alphamale
I'm getting the feeling that the Basslink is not quickly removeable without undoing fasteners?
Old Jan 3, 2008 | 12:52 PM
tidmutt's Avatar
I'm also interested in a Basslink install that allows me to remove it fairly easily. So I'm hoping I can install a Basslink in such a way that I can remove it when I know I'll need the space.
I found this thread where someone claims they held it in place with velcro:
https://www.rx8club.com/showthread.p...asslink+velcro
Maybe that will help?
Don't know much about car stereo hardware etc. but I'm assuming you could remove the basslink and the rest of the system would still function.
Old Jan 3, 2008 | 01:02 PM
HCTR154's Avatar
Removal only takes a couple of minutes. I use a rechargeable drill to remove the screws and disconnecting the actual unit doesn't take that long. Your back will be sore longer from all the weird twisting you'll have to do, than it will take to get the Basslink our of your trunk.
Old Jan 3, 2008 | 01:52 PM
alphamale's Avatar
alphamale
The velcro idea crossed my mind, but it wasn't apparent to me how the side that attaches to the carpet would work. I figure you would glue one side of the velcro to the bottom of the bracket, but I wonder about gluing to a carpet.
Old Jan 3, 2008 | 02:04 PM
kwolfman's Avatar
No Gods For Me
I put one of the Mazda RX8 trunk trays in my trunk (about $50). When I mounted my basslink, I just velcroed the legs to the trunk tray. I made sure to use industrial strength velcro. That basslink wants to move either through its own vibration or just driving around. I have had no problems with this setup. I can remove my basslink in a minute, although that velcro is incredibly strong.
Old Jan 3, 2008 | 10:42 PM
really,
might look into this idea, gluing to carpet will not work..
http://www.jegs.com/webapp/wcs/store...63087_-1_11333
Old Nov 21, 2009 | 01:35 PM
Roxie79's Avatar
My Fuzzy Mechanic
My baselink came with brackets that screw into the floor of the trunk (or wherever you mount it). After that, the baselink itself mounts to the two brackets with two 8-inch or so bolts. Takes like two minutes in all to unscrew the bolts and disconnect the wires for removal.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
ShellDude
Oct 1, 2015 09:55 PM
pjwermuth
Sep 28, 2015 11:36 PM
Learners_Permit
Sep 27, 2015 07:38 PM
