Anyone got a rough idea of exhaust noise on a single silencer system?
Old Dec 27, 2007 | 09:57 AM
PhillipM's Avatar
Yes, bit of a strange question this one, but basically we are limited to 98dB in our line of competition, so we've got to make up our exhaust system with that in mind.
Now, the headers are 2", 2mm wall stainless so they should dampen some of the noise down (37.25" to the collector for the interested, bar the merged centres, which join earlier to keep mixed pulses out of the way of the ones we can actually use to good effect), after this we are switching to 2.5", 1.6mm wall stainless, and we are hoping to get away with a 14"x7"x5" oval muffler.
Now, we are hoping that would be just enough, but if need be we can squeeze anther muffler in there, but if anyone has a similar setup - tubular headers + big single muffler - how loud is your car?
Old Dec 27, 2007 | 10:05 AM
expo1's Avatar
He's as bad as Can
Could this Racing Beat exhaust be of help?
Old Dec 27, 2007 | 10:10 AM
PhillipM's Avatar
Anything relevant helps
I've been flicking through the forums for a while looking for small power gains (reluctant to pull a new crate motor apart for machining, so bolt on for now), and read the snippet about the original HP claims being for an engine with no ancillaries, now, given we'll never be below 5krpm, we could probably run a seriously under-driven crank pulley, maybe half-speed, but how much difference does that really make to the cars?
Old Dec 27, 2007 | 01:21 PM
PhillipM's Avatar
While I'm at it, is it possible to blank off the intake oil feed system (running pre-mix), or will it have to be kept in addition?
Old Dec 27, 2007 | 01:38 PM
romycha1's Avatar
Are you talking about the Sohn Omp Adapter?
Old Dec 27, 2007 | 01:50 PM
PhillipM's Avatar
I have no idea!
The little oiler unit that feeds to the intake ports to lubricate the rotor seals.
Old Dec 27, 2007 | 01:53 PM
Keef's Avatar
the shit starter
Putting a breather filter on the intake oil part of the feed system, then blocking the intake part creates a slightly different response in throttling...
Also running pre-mix all the time, after 2,000 miles has given me a different change in exhaust tone under WOT. You could probably achieve the same thing by running different oils, but having run Idemitsu's pre-mix such makes 7,000 RPM roar almost too loud at times... It all flies though, so I have no worries... And to run pre-mix all the time your going to need this!!!
romycha1's Avatar
This is a forum member's(GTAW) website I believe.
http://www.turborenesis.com/ompadapter.html
Old Dec 27, 2007 | 01:59 PM
PhillipM's Avatar
So it can't just be blanked off and just use purely pre-mix in with the fuel then?
Old Dec 27, 2007 | 02:01 PM
romycha1's Avatar
If you block it off, then how would you lubricate the seals?
Old Dec 27, 2007 | 02:02 PM
PhillipM's Avatar
2-stroke oil in the fuel?
Or have I missed something here?
Old Dec 27, 2007 | 02:09 PM
PhillipM's Avatar
Originally Posted by Keef
having run Idemitsu's pre-mix such makes 7,000 RPM roar almost too loud at times... [/URL]
Cleaners in the 2-stroke oil lifting carbon off the exhaust ports perhaps?
Seen it with a few 2-strokes when they've switched oil brands.
Old Dec 27, 2007 | 02:23 PM
loud
how loud depends on the silencer
Old Dec 27, 2007 | 02:26 PM
PhillipM's Avatar
I guessed that, just (perhaps in vain) hoping someone had a similar setup and knew the rough noise output.
Old Dec 27, 2007 | 02:48 PM
romycha1's Avatar
I don't think that would be enough to oil the seals... would it?
Old Dec 27, 2007 | 02:51 PM
PhillipM's Avatar
Can't see why not, doesn't inject a lot of oil anyway does it?
Old Dec 27, 2007 | 03:00 PM
Brettus's Avatar
Boosted Kiwi
you'll be fine as long as you run a rich mix . Racing Beat recommends 80:1 for maximum power .
Old Dec 27, 2007 | 03:04 PM
PhillipM's Avatar
Thought so, cheers, so how do I stop the engine burning my lovely Millers synthetic then?
Old Dec 27, 2007 | 03:14 PM
Brettus's Avatar
Boosted Kiwi
Someone suggested to me that you can take the oil metering pump apart and put the return spring on the pistons on the other end - rendering the pistons inoperable without triggering the computer into "limp mode"
MM also suggests buying another OMP and connecting it electrically and strapping it out of the way somewhere ....
Old Dec 27, 2007 | 03:18 PM
PhillipM's Avatar
be running a Microtech ECU so fault codes aren't a problem!
I can blank it off without any problems then? As you can guess I haven't taken it off for a look yet!
Old Dec 27, 2007 | 03:23 PM
Brettus's Avatar
Boosted Kiwi
BTW - they are running an 8 in production class here with a single muffler . No numbers on it but they seem on a par with other cars on the track noise volume wise . They dont have a header and the stock cat is in place with all its internals removed .
Old Dec 27, 2007 | 03:29 PM
Brettus's Avatar
Boosted Kiwi
You won't be able to drive the car if it goes into limp mode so being able to reset the codes will not help you there - you kneed to do it in such a way that electrically the computer thinks it is still working . You probably don't want to blank off the hoses - oil does not compress
can I suggest you don't go with microtech unless you are very intimate with them - I think they don't cope well with the drive by wire . The interceptor x sold by Mazsport is a modified Microtech made just for the 8 . I run a unit from Aussie (Powermod)which works really well and is cheaper than the Int x. There are others around as well .
Old Dec 27, 2007 | 03:36 PM
PhillipM's Avatar
That's promising then, saves some length on the rear frame if we only need one silencer!
We have the RX-8 specific unit, but we're using a duratech throttle body instead anyway, as fly-by-wire is not allowed under our regulations.
Old Dec 27, 2007 | 03:48 PM
Brettus's Avatar
Boosted Kiwi
What kind of car is it ?
Old Dec 27, 2007 | 03:52 PM
PhillipM's Avatar
Little 2wd buggy, similar to a 1600 class but a lot smaller and narrower for rally work.
