Is this even worth it?
Old Dec 18, 2007 | 12:14 AM
tajabaho1's Avatar
Destroying Threads
"Gold Reflective Film
Now On Sale!
The Gold Reflective Film is an aerospace material capable of reflecting 78% of all radiant heat with continuous operating temperatures of 450 degrees centigrade. The material is metalized polyamide polymer laminated glass cloth with a high temperature pressure sensitive adhesive. The film is lightweight at only 5oz per square yard, and is easy to apply and remove. Typical applications include; but are not limited to, engine covers, side pods, suspension, under trays/floors, seat bottoms, fire walls and bulkheads. The minimum air gap to heat source is just 1mm.
Gold Reflective Film forms to any shape, is far more reflective with greater weight saving and is preferred over aluminized cloth and waffle board.
CONSTRUCTION: Metallized polyimide film laminated to glass cloth with high temperature acrylic adhesive protected by a release liner.
FEATURES: Excellent heat reflective characteristics and is easy to install. Withstands 675�F of radiant heat for a minimum of 8 hours
APPLICATION: Heat reflective material used in the auto racing industry.
Price is PER linear foot (1' x 2')! For a general idea of how much you want, to cover firewall it takes roughly 5 Feet with some for leftover!
Shipping price will be added in at checkout, it is a flat rate of $10 for less than 10 feet. More than 10 feet is flat rate of $15."
www.eastcoastdrift.com
I know this thing is like uber freaking overpriced
but seeing as the Rx8, and rotaries in general produce a crapload of heat. I wonder whether this thing would be worth it to put on the intake piping and manifold?
probably not for the NA people but maybe for the FIed folks?
just wonderin since my friend says its very good and actually works
granted he used it as aluminum foil.......sigh
Old Dec 18, 2007 | 04:34 AM
The Ace's Avatar
Greek Power
It is not soooo overpriced actually, and it does work. However, you have to think about the possible applications. The problem with 7s and 8s is not that the heat permeats everything, it's that the heat does not escape so easily the engine bay...
Old Dec 18, 2007 | 01:27 PM
tajabaho1's Avatar
Destroying Threads
so its not worth it on our cars
Old Dec 18, 2007 | 02:41 PM
rotarygod's Avatar
You do see that used on race cars so it definitely works. The Speedsource RX-8s wrap the intake boxes with it.
Old Dec 18, 2007 | 03:46 PM
tajabaho1's Avatar
Destroying Threads
lets say for FI application, lets go with turbo, would it be worth it to wrap this around the intake tubes and manifolds? the turbo? etc etc? will it make a noticeable difference?
Old Dec 18, 2007 | 06:47 PM
c0ldf1ame's Avatar
my guess is that this can be used to insulate the cold side? i always see the hot side wrapped in exhaust wrap to prevent heat from getting out,
Old Dec 19, 2007 | 04:25 AM
The Ace's Avatar
Greek Power
There are materials that work for both goals: keeping heat out, or keeping heat in. The reflective materials are usually to keep heat out of whatever we are trying to insulate (mainly for intake and air piping), while the cotton/glass heat resistant materials are usually used to keep heat in (mainly for headers and exhaust).
Old Dec 19, 2007 | 10:38 AM
tajabaho1's Avatar
Destroying Threads
makes perfect sense
40$ per square foot, worth it though?
Old Dec 19, 2007 | 11:11 AM
rotarygod's Avatar
They somehow consider a linear foot 1' x 2' so it's $20 per square foot.
Old Dec 19, 2007 | 12:37 PM
tajabaho1's Avatar
Destroying Threads
ahhhh, well, I guess if you can shell out 8.5k for a mazsport turbo kit, another 100$ for this film wont hurt much.......
Old Dec 19, 2007 | 01:21 PM
Are you going Mazsport Turbo kit ?
Old Dec 19, 2007 | 01:22 PM
tajabaho1's Avatar
Destroying Threads
we'll see real soon
Old Dec 19, 2007 | 03:43 PM
olddragger's Avatar
it also looks so trick!
oscd
Old Dec 19, 2007 | 03:47 PM
tajabaho1's Avatar
Destroying Threads
^ which is a problem, I'd spray paint everything primer black in my engine bay once I'm finished modding, if the cops look, I'll just be like, nope, all stock
Old Dec 18, 2009 | 07:02 AM
altspace's Avatar
Eccentric Shafting
I love it! The RB intake pipe is covered as well, though not shown here.
Old Dec 18, 2009 | 07:07 AM
maxxdamigz's Avatar
Baro Rex
Did you time it for the 2 year anniversary of the original post?
Old Dec 18, 2009 | 08:06 AM
JinDesu's Avatar
went back to srsly broke
It looks... a little tacky....
I suppose it'd be great on items you don't want heated, like the intake tube to slow down heatsoak in traffic, but that'd be pretty hard to put on.
Old Dec 18, 2009 | 08:41 AM
there are better insulators for le$$, just because it reflects high heat sources like a glowing red exhaust header doesn't stop whatever it's wrapped on from soaking up lower heat sources like radiator heat
it's very tacky, how else do you expect it to stay in place?
Old Dec 18, 2009 | 03:27 PM
altspace's Avatar
Eccentric Shafting
^Ha! I did it for 2 reasons.
1. I got the idea from Speedsource and ROAR racing.
2. I enter my car in many local shows and the crowd/judges loves it (as do I). My collection of 1st place trophies proves it. LOL.
Is it worth it? Well for me I got the material through sponsorship. So I said why not try it and see what happens.
Old Dec 18, 2009 | 03:51 PM
pdxhak's Avatar
Official Post Whore
Woot! for 2 year thread revival
Old Dec 18, 2009 | 04:54 PM
altspace's Avatar
Eccentric Shafting
Right?! Talk about perfect timing.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
DG07
Sep 28, 2015 10:58 AM
