What tools do i need for my aem intake and agency power pulley.
Old Dec 12, 2007 | 04:15 PM
R3v9K's Avatar
R3V9K
Hey guys my order with my intake and pulley should arrive tommorow. In the mean time what tools do i need to install both? Also does anybody have simple or straightforward directions on how to install the Aem intake and agency power pulley? Thanx
Old Dec 12, 2007 | 04:17 PM
laythor's Avatar
I zoom therefore I am.
are you buying them used?
otherwise the intake will come with instructions, not sure about the pulley
Old Dec 12, 2007 | 04:18 PM
10mm socket and a philips head screw driver. Pretty much all you need to take an RX-8 apart.
Old Dec 12, 2007 | 04:54 PM
tajabaho1's Avatar
Destroying Threads
yea, but 24MM socket for the pulley, and oh, use impact
Old Dec 12, 2007 | 04:56 PM
staticlag's Avatar
The Professor
read the DIYs
Old Dec 12, 2007 | 05:02 PM
WoodsOfGreenRx8's Avatar
^^ Dan, you are such a bully!!
Old Dec 12, 2007 | 06:16 PM
chickenwafer's Avatar
Nope
Um, no
There are 4 10mm bolts holding the crank pulley- that huge nut is for the e-shaft.
The AP pulley doesn't come with instructions, so find the DIY
Old Dec 12, 2007 | 06:18 PM
chetrickerman's Avatar
the 24mm is for the alternator nut, which you dont need to take off if you have the agency crank pulley. you need 12 and 17 mm sockets too
Old Dec 12, 2007 | 10:14 PM
megaman's Avatar
yes use impact, i didnt thats why im being charged $450 by the dealer to remove the broken bolts from my eccentric shaft. i think they might do it under warranty but im skeptic. anywho...................good luck, and make sure you check, after a week of putting on the pulley, that the bolts are still there or not loose.
Old Dec 12, 2007 | 10:59 PM
tajabaho1's Avatar
Destroying Threads
? oh sorry, I had UR pulley, I had to get a 24 socket to remove the alternator pulley
use impact if u dont want to cry later
Old Dec 13, 2007 | 12:42 PM
R3v9K's Avatar
R3V9K
Sry, but what exactly is impact?
Old Dec 13, 2007 | 12:52 PM
I believe they are referring to an impact gun.
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
Billy Marcial
Mar 1, 2018 06:50 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
MrORAN6E
Jul 24, 2015 09:32 AM
AussieGray
Jul 16, 2015 03:58 AM
