rx-8 dead battery
Old Nov 26, 2007 | 08:51 AM
jeff payne's Avatar
rx-8 dead battery
HELP!!!I have tested all the fuses and still have something drawing volts.
2004 rx-8
Old Nov 26, 2007 | 09:06 AM
are you sure your battery is not *bad* in the first place?
Old Nov 26, 2007 | 09:13 AM
Brettus's Avatar
Boosted Kiwi
2004 rx-8
ummmm - you mean drawing current don't you ?
how exactly , do you know there is still a drain on the battery ?
Old Nov 26, 2007 | 12:08 PM
jeff payne's Avatar
dead battery
ok current. i used a volt meter between the negitive cable and the battery post and removed each fuse and still showed a current being drawn from something.this is my second battery.
Old Nov 26, 2007 | 12:31 PM
VolcomStoneX's Avatar
Hi, Let's Make Out
I had the same problem, i had to have it towed to mazda, i was at my girlfriends house...the next morning...poof, it was dead
Old Nov 26, 2007 | 03:00 PM
Brettus's Avatar
Boosted Kiwi
When you say you used a voltmeter - do you mean you measured volts or amps ?
You need to measure amps .
the light in the boot stuck on is a common one that is hard to trace .......
Old Dec 25, 2007 | 12:26 AM
Racer X-8's Avatar
Coming thru in waves...
Originally Posted by Brettus
... the light in the boot stuck on is a common one that is hard to trace .......
I'm having a problem with what seems to be a dying battey too. To check the trunk light, I just put my pocket camera in there and let it take a movie of me closing and opening the lid 3 times. With the camera lying on the bottom on its back, it was looking right at the light. (My light works like a champ)
Old Jan 14, 2008 | 04:39 AM
Sohaib's Avatar
low battery, and it wont start with jump starter
Hey guys, need all the help i can get! i was away for 3 weeks and when i came back the siren seemed to be beeping in a very low volume. The battery was almost empty. Now when i try to startup with a jump starter the siren starts to beep instantly when i connect it to the battery and it wont stop no matter what i do. What seems to be the problem?? plz help guys..
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
atmd
Aug 19, 2015 12:43 PM
Eirulisse
Aug 15, 2015 12:34 PM
T_Mags
Jul 24, 2015 11:29 AM
