13b T2 Swap
Old Nov 4, 2007 | 05:41 PM
ToguePirate787's Avatar
Rotary 4 Life
13b REW Swap
Hey guys, I was hoping you guys can shine some light my way about the 13b REW swap. Here is my situation. I am coming out of my warranty and I have a 13b REW engine from 93+ rx7 and i was wondering... If i swap the motor into the RX8 am i going to have registration issues when it comes to register my car? Has anyone done the swap and registered the car without problems, such as: Having an older motor in a newer car and not a newer motor in an older car? Has anyone had any problems here is California? That is the only thing that is bugging me and keeping me from starting the Swaping proccess. Thanks guys.
Old Nov 4, 2007 | 05:48 PM
cjwaggs's Avatar
If you got a 93' engine it's a REW motor not a turbo II motor.
Old Nov 4, 2007 | 05:49 PM
Kel Rx8's Avatar
if your not 1st your last
t2 threw me off, we usually use that term as a second gen turbo II
13brew or A Brew is a 93+
anyway there was a guy in california with a Brew swap on the for sale section lookin for some one to swap engines with him.Im sure he can provide you some answers.good luck
Old Nov 12, 2007 | 06:56 PM
cptpain's Avatar
California law states that any engine swap done to a vehicle must be an engine of the same year or newer and must keep all emissions components intact and must be functioning to meet smog regulations for the engine.
theres alot more things involved to swap in an -REW motor than just replace engine harness and custom mounts and add other ancillary parts such as a stock or programmable ecu, convert the fly-by-wire throttle to cable linkage, etc....
you're better off buying a turbo kit with the interceptor-X ecu from Mazsport than swap an -REW.... it will be much less expensive than the swap.
Old Nov 12, 2007 | 09:27 PM
LionZoo's Avatar
road warrior
I've always thought swaps required you to meet emissions laws of the newer component e.g. if your car is a 2000 and your engine a 1995, you have to meet 2000 emissions regulations. However, if your car is a 1995 and your engine is a 2000 you still have to meet 2000 regulations. In my opinion, it's not worth it as I don't think you can get the 13B-REW to meet emissions and even if you do it'll be quite a battle to get it registered.
Ian_D
Rotary Swaps
26
Jan 21, 2017 02:23 PM
Fickert
Sep 9, 2015 01:21 PM
RX7.9
Jul 20, 2015 12:01 PM
shambo
Jul 18, 2015 02:07 PM
Crimson
Mar 25, 2009 04:38 AM
