RE: Removing the 9000 rpm limiter
Old Oct 19, 2007 | 10:38 PM
Lasse wankel's Avatar
Lasse wankel
I have searched but not found a way to get rid of the stock 9000 rpm limiter. This causing me trouble when i dyno test my RX-8 on my RotoTest becausse i must go 500 rpm higher than the dyno rpm. Is there a kit or could i disconnect the rpm limiter myself? Thanks in advance!
/Lasse
Old Oct 19, 2007 | 10:45 PM
Brettus's Avatar
Boosted Kiwi
/Lasse
couple of things i'm aware of :
Interceptor x takes control of fuel and spark so you can set the limiter where you like .
Racing Beat flash adjusts limit to 9300 rpm
Old Oct 20, 2007 | 12:57 AM
What is the point of revving it more ? You're losing a lot of power after 9500 rpm.
Old Oct 20, 2007 | 01:01 AM
i would bet he is not.
Old Oct 20, 2007 | 03:32 AM
Cobb Accessport, just be patient
Old Oct 20, 2007 | 02:46 PM
Lasse wankel
Thank you Brettus! But how? That is where to find the info on how to do it.
/Lasse
Old Oct 20, 2007 | 02:50 PM
Brettus's Avatar
Boosted Kiwi
You would need to buy the Interceptor x from Mazsport - Scott would know how to do it ......
Old Oct 20, 2007 | 02:51 PM
Lasse wankel
I don't know when my power starts dropping becausse i can't dyno any higher than 8500 rpm becausse of rpm limiter cutting in. On the road it goes really quick up to 9000 rpm even on 3rd gear.
Old Oct 20, 2007 | 02:55 PM
Lasse wankel
Ok thanks! I will send him an e-mail! What you think about my dyno test with the RotoTest? It,s up now on aftermarket modifications.
/Lasse
Old Oct 20, 2007 | 02:57 PM
Brettus's Avatar
Boosted Kiwi
ah - I see what you are saying now !
Did you know that 9000rpm on the dash gauge is only 8500 rpm at the motor ?
Mine goes to 9500 on the guage (9000 at motor) . Does yours not go that high ?
Old Oct 20, 2007 | 03:49 PM
Lasse wankel
Mine goes excactly as yours!
/Lasse
Old Oct 20, 2007 | 10:12 PM
bret,
does the powermod not allow you to raise the rpm? i know yours is jdm locked at top speed.
Old Oct 21, 2007 | 12:34 AM
Brettus's Avatar
Boosted Kiwi
no - it only modifies what the ecu is already doing with spark and fuel
Old Oct 21, 2007 | 10:48 AM
zoom44's Avatar
racing beat flash is available now OR wait for Cobb at the end of the month
Old Oct 21, 2007 | 10:50 AM
zoom44's Avatar
oh um Astra Racing in Italy does the same kind of flash as Racing Beat i believe. Send the pcm they open attach a com port , flash and send back
Old Oct 21, 2007 | 11:10 AM
devildog1679's Avatar
Do you know something we don't? Please do tell
Old Oct 21, 2007 | 11:18 AM
zoom44's Avatar
im just reading between the lines. people saying lots of stuff at sema. "very soon" etc . SEMA is Oct. 30th
Old Oct 21, 2007 | 11:30 AM
Does that mean we can disable a lot of annoying CELs ?
and CELs from TC/SC ?
Damn, I have 13 K miles left warranty on my car ...
Old Nov 12, 2007 | 07:13 PM
cptpain's Avatar
if you rev to 9k on the road then how is it possible to only rev to 8500 on the dyno?
it seems like the its the dyno software or the dyno operators problem and not the car.
do you have an auto or manual transmission?
if its auto, then you dont want to risk revving so high anyway cause it wasnt meant to take such abuse or increase in power over a certain degree.
if its manual then you shouldnt have any problems with hitting 9-9.5k
Old Nov 12, 2007 | 07:38 PM
Renesis_8's Avatar
its obviously a manual
as stated in many other threads, the tachometer is not accurate.
________
California dispensaries
Old Nov 13, 2007 | 09:21 PM
doesn't work on the US cars, not compatible with our security system software
EDIT: he's in Europe so it may be an option, but Alex is no longer with them
Old Nov 14, 2007 | 11:45 AM
zoom44's Avatar
oh dang where'd he go?
Old Nov 14, 2007 | 07:31 PM
I don't know, I heard it through Astra not Alex
one of these should be good for a contact there:
rreginato@astraracing.com
svatanen@astraracing.com
RevMeHarder
Jun 1, 2026 02:30 PM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
