Fan mod - track test
Old Oct 19, 2007 | 01:49 PM
Brettus's Avatar
Boosted Kiwi
The following chart shows two track sessions of about 14mins each . In the first session both fans were on full for the whole time . In the second session both fans were turned on at 98deg C and off at stock Mazda switch point . Ambient temp was about 18deg C and the track is a very high speed one with a long straight where I was reaching up to 225km/hr .
Note how much longer the temps take to rise when the fans are always on and the highest temp reached is approx. 2-3 deg less .
Relevant cooling info :
running redline water wetter and antifreeze at approx 15%
20% Underdrive pulley
Synthetic oil
piggyback ems with afrs around 13
Old Oct 19, 2007 | 02:28 PM
Red Devil's Avatar
I'm assuming you rigged up the fan mod yourself?
And good to see, I've been curious about this for a while.
Old Oct 19, 2007 | 02:32 PM
Spinning Sushi's Avatar
I <3 Sushi
I was always skeptical about the Fan Mod but it looks like you prove that it works even though it kept the ambient engine bay temperature by only two or three degrees.
Old Oct 19, 2007 | 04:07 PM
Brettus's Avatar
Boosted Kiwi
Red Devil , yes I'm controlling them with my piggyback .....
In hindsight I should have done the second test with the fans disconnected all together . That would really have shown the difference .
Old Oct 19, 2007 | 09:24 PM
olddragger's Avatar
nice! validates what we have been saying all along, the damn radiator is at too much on a angle and too much stuff right behind it to flow good without some assistance
Nice work!
Olddragger
Old Oct 19, 2007 | 10:51 PM
Brettus's Avatar
Boosted Kiwi
Nice work!
Olddragger
thanks OD - notice I took your advice and do a cool down lap - see end of blue line
Old Oct 23, 2007 | 06:40 PM
olddragger's Avatar
Smart Man--i can die now----- my work is done.
lol
Man look at the difference in the cool down lap ---damn.?
again good work
OD
Old Oct 23, 2007 | 09:12 PM
if the radiator is oriented at a smaller angle it would then have less area/volume all else being equal, that will hurt more than it will help
the real issue is that it doesn't have enough volume for it's given area to sustain continuous WOT situations. It needs to be much thicker (increased volume, lower fluid velocity, more time for fluid to disperse heat to the outer surfaces), which is addressed with the Mazda Motorsports radiator.
Old Oct 23, 2007 | 11:19 PM
staticlag's Avatar
The Professor
where can I get that?
Old Oct 23, 2007 | 11:43 PM
DOMINION's Avatar
I don't buy Kool-Aid
Its the Mazspots fan mod.
Read up.
Old Oct 23, 2007 | 11:48 PM
DOMINION's Avatar
Lightbulb
Nice work!
Olddragger
What if it was vertical? and had a relocation kit that would move it up front more? if you can that is.
Old Oct 25, 2007 | 08:17 PM
olddragger's Avatar
it would have a much better flow---also would help if all the "stuff" behind it could be removed. It also helps a little to remove the front bucktooth on the airdam and to NOT use screens.
all said and done on a 80F day normal suburb driving coolant temps 180F, oil temps at 165F I have the rb flash that turns on the fan early and the mazmart water pump.
Of course all of that is about to change.
OD
Old Oct 28, 2007 | 01:20 AM
DOMINION's Avatar
^Thank you.
So how do I ditch this?
Its under the intake box. I'm going to take off my front bumper and see what I can ditch next weekend.
Jesus Martinez
44
May 6, 2025 08:09 AM
rotorocks
47
May 11, 2016 03:23 PM
Nisaja
Aug 6, 2015 01:27 AM
AussieGray
Jul 16, 2015 03:58 AM
