Cant pass 4000 rpm
Old Oct 8, 2007 | 03:46 AM
Syco_16's Avatar
Cant pass 4000 rpm
ok for some reason i cant pass 4000 rpm on my ride. on parked or on the go. can some one give me some advice? plz
Old Oct 8, 2007 | 03:57 AM
StealthTL's Avatar
Metatron
Is it smooth or rattly?
S
Old Oct 8, 2007 | 04:27 AM
bad kitty..
btw, not enough info.. year miles auto or mt.
Old Oct 8, 2007 | 12:29 PM
Syco_16's Avatar
its a 04 about 43k and MT its smooth until you get to 4000rpm then it just drops and on the drive feels like a beginer getting off of first gear.
Old Oct 8, 2007 | 12:37 PM
Sounds like ECU is in safe mode from something. Read the CEL code...and it may tell you what's not working. Try and reset the ECU after that. If it works, it might just be a glitch. If it comes back right away.... There aren't that many things that will set it into safe mode right away MOP is one...and ECT sensor is another..IAT temp sensor might as well. Also the Eccentric shaft sensor....
Good luck
Old Oct 8, 2007 | 12:50 PM
alnielsen's Avatar
I agree with Swoope, I suspect a clogged cat.
Old Oct 8, 2007 | 03:26 PM
dagwood15t's Avatar
drifting king
man i had this same problem and the solution was i had a melted cat so i put a race beat race pipe in and now the problem is gone.
Old Oct 8, 2007 | 04:43 PM
Even though it may be a CAT the ECU safe mode will do the same thing.
Try the reset. Go to the sticky section in the tech forum. It will tell you how to reset.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Michael Bryant
Oct 12, 2015 03:07 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
