Fuel Pressure Sensor Location
Old Sep 29, 2007 | 10:26 PM
RXSeven1's Avatar
dorito spinner
i need to install my fuel pressure sensor and i was curious where people have thiers located? i noticed the fuel like in some cheesy plastic and might be hard to put there.
Old Feb 15, 2010 | 09:17 PM
bump, somebody help a rotardo brother out (me)
Old Feb 17, 2010 | 10:32 AM
Damn, I looked everywhere for that damn thing. Good find.
Old Feb 17, 2010 | 11:33 AM
MazdaManiac's Avatar
I took a spare line, removed the red connector ends and put them in a piece of soft line with a "T" that had an NPT 1/4" female port on it from Ace and replaced the OE plastic line with that.
Old Feb 17, 2010 | 02:40 PM
I too doubt it's custom made. I got a new catalog from Pegasus Racing yesterday, they have tons of fittings, etc. I will look for it.
Old Feb 18, 2010 | 12:47 AM
ebb's Avatar
ebb
Aeromotive 15120 is all you need. It has quick disconnect on both ends, a female and male. 30 seconds to install, factory line remains intact and no clamps or extra crap hose. 1/8 npt port and AN06 port which I have closed off with plug that came with the part. 50-60 dollars well spent.
http://aeromotiveinc.com/products-pa...6-access-port/
Old Feb 18, 2010 | 12:53 AM
Originally Posted by TeamRX8
It looks like the OE connector attaches to one side and a short piece of rubber hose with clamps on the other?
No.
The left side goes on the OEM hard line and the right side goes into the OEM disconnect on the soft line.
Take the picture and rotate it 90° anti-clockwise and it should make sense.
Nice find.
Old Feb 18, 2010 | 12:59 AM
ebb's Avatar
ebb
Originally Posted by MazdaManiac
No.
Nice find.
that is right maniac, just plugs into both ends. Simple
Old Feb 18, 2010 | 01:07 AM
No.
Nice find.
Ebb posted that as I was typing, I was referring to the PTP part - deleted that post anyway because it no longer matters
thanks Ebb, still $53 but it's the perfect part
Old Feb 18, 2010 | 01:19 AM
Charles R. Hill's Avatar
Owner of BHR
How's about $55, shipped, from BHR?
That black anodizing goes quite well with several things BHR offers, too.
Old Feb 18, 2010 | 01:24 AM
damn, I ordered it, had no idea you had it
let me see if I can cancel
Old Feb 18, 2010 | 01:26 AM
Hmm. We should offer an entire pressure monitoring rig...
Old Feb 18, 2010 | 01:29 AM
Owner of BHR
How'dja like the fuel/nitrous gauges in my car the other night?
Old Feb 18, 2010 | 01:34 AM
Owner of BHR
I actually chose local pickup if available, for under $53. If it's not then I'll cancel and order from you instead. Still need to buy the Prosport fuel pressure gauge/sensor, already have oil/water temp setup with the Racing Beat ashtray gauge pod and sensor mounts
You should ALWAYS check with BHR first as you have "special" pricing.
Old Feb 18, 2010 | 02:18 AM
see the descriptive r-word in the 2nd post
glad I bumped this thread, thanks again Ebb
Old Feb 18, 2010 | 10:46 AM
Felt like the cockpit of a Mig, though I think I described it differently at the time.
Old Feb 18, 2010 | 10:56 AM
That is an awesome part, now to figure out which gauge to get and where to put it.
Old Feb 18, 2010 | 02:30 PM
Re-ordered through BHR
Old Feb 18, 2010 | 03:10 PM
Brettus's Avatar
Boosted Kiwi
These fuel pressure guages - can they give you a warning buzzer to warn of potential starvation .
Would it be fast enough to prevent a detonation event ?
Old Feb 18, 2010 | 03:40 PM
Yes on the warning
probably not for detonation depending on how severe it was and where you set the limit, which would need to be below the minimum pressure that the system might see during normal operation
Old Feb 18, 2010 | 04:04 PM
olddragger's Avatar
it takes a lot of starvation to lean it out to the point it may detonate. I know----sigh.
Engine quits when there is a sudden loss of adequete pressure---remember all the fuel starvation issues on track--but those are without detonation---right?
This set up could sure help for track people and for tuners.
I cant put anymore gauges in----next thing you know I will have to have just a "dash" Is it Christmas yet?
OD
Old Feb 18, 2010 | 10:11 PM
Owner of BHR
A coupla LCD gauges backlit in blue and you thought that was cluttered?
Musta been the Magellan GPS that threw you off..........
Oh, I forgot the AccessPort velcro'd to the dash.
Old Feb 19, 2010 | 07:12 AM
Kane's Avatar
Senior Member
Mine changes color at 55 psi, then flashes at 50 psi... so it's kinda like an idiot light. But at least when I see bright green or red out of the corner of my eye I come off the gas.
Old Feb 19, 2010 | 11:08 AM
I have my sender hooked up to an analog input on my E-01 boost controller.
When the fuel pressure goes below 50 PSI, it beeps, flashes and pulls my wastegate to dump boost.
Old Feb 19, 2010 | 11:10 AM
TX
Impressive.
