loud trunk!
Old Sep 28, 2007 | 07:24 PM
kosmokramer1357's Avatar
loud trunk!
how can i stop the raddling in my trunk its killing me... i know have a sub in the trunk is going to make some noise the the deck is hitting another piece of metal and its really loud
Old Sep 30, 2007 | 03:09 AM
yushinrt's Avatar
get sounddeadening
Old Sep 30, 2007 | 11:43 PM
firebirdude's Avatar
User and Abuser
Same problem. One 12" in a large vented design box.... it moves A LOT of air. I've tried wedging cardboard up in the trunk lid. No improvement at all.
And sound deadening won't always help with rattles. Infact, rarely. It is used mainly to keep road noise down. Rattling is ....obviously.....two pieces vibrating against each other. Unless the sound deadening just happens to be wedged between the offending pieces or simply the added weight of the deadening was enough to cure the vibrations.... you're not going to be happy with the result.
Old Sep 30, 2007 | 11:57 PM
NgoRX8's Avatar
dynomat?
Old Oct 1, 2007 | 12:37 AM
WikkedOne's Avatar
Deals on wheels
Ngo - its actually called "Dynamat" and yes it will help.. but I think what yush is having is the same thing i had - its where the back of the trunk lid (the part closest to the car when the trunk is open) is rattling against the trunk itself on the "outside" of the weatherstripping... right where the trunk lid meets with the rear window... you need to find a way to pad the very edge of that trunk lid and the car - maybe put some dynamat in there or something
Old Oct 1, 2007 | 01:59 AM
yushinrt's Avatar
i can't really bother takeing the sub box and my amp out buy i will show you the truck lid i just sound deaded it makes lot of deffrent recomend for every one lol
Old Oct 1, 2007 | 09:29 PM
Juice's Avatar
I made some poos
When i had my subs the trunk rattled right near where it is closest to the back windshield. When i pressed down on the trunk near the back it stopped. So what i did was get a rubber mallet and pounded the back (where the weatherstripping attaches) up so it would put more pressure on trunk lid. Stopped most of the rattles and there are no negative effects. Also found some rattles from the retaining clips that hold the top of the back seats (2 on each seat). Those rattled really bad and it sounded very tinny/metallic even though they are plastic. Dynamat in between the plastic and metal and no more rattles.
Old Oct 1, 2007 | 10:06 PM
User and Abuser
Just so my point is clear..... anything in between those panels would have solved your problems. Start with cardboard, because it's free.
I'm having the same rattles from the rear seats. Also, my sunroof shade vibrates too.
Old Oct 2, 2007 | 09:40 AM
Juice's Avatar
I made some poos
^^ I know what you are saying firebirddude. I just had some extra dynamat because i did the whole rear deck, because of the new 6x9s I put in. If I didn't use the Dynamat then i propably would have used electrical or duct tape in layers, something with a bit of rubbery consistency not carddboard. Or maybe some tape AND cardboard, makes it thick and rubbery. Ehh, anyways there are alot of options to stop rattles but IMO dynamat works really well for most of them.
Old Oct 9, 2007 | 09:09 PM
thanks juice your advice worked really well I just put in two 10 inch Boston g3 subs
Old Oct 9, 2007 | 10:32 PM
Juice's Avatar
I made some poos
No Problem Man
cliffkemp
Dec 24, 2024 10:48 AM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
GK1707
Sep 27, 2015 07:33 PM
