Pettit Super Charger Owners
Old Dec 15, 2007 | 02:11 PM
  #851
shinka213's Avatar
Pettit fangurl <3
spoke to moon about an hour ago...
he left WPB around 1230....was about 100mi outta of the city when i called him...
will keep you posted....
PS...on the maf housing, i will be getting the new one and a new air filter..but im not sure of the size...
Old Dec 15, 2007 | 05:16 PM
  #852
munche187's Avatar
&quot;MuNcH-E&quot;
I am sure he'll be gettin' his "kicks".
I would hope 3.5, or even a little bigger, so you guys don't outrun the available MAF voltage.
To late.
Old Dec 15, 2007 | 06:03 PM
  #853
Charles R. Hill's Avatar
Owner of BHR
For what?
Old Dec 15, 2007 | 07:20 PM
  #854
olddragger's Avatar
already ran out of voltage?
I am looking into modifying the RB maf pipe and actually using the RB revi k/n filter. Leave out the Velocity stack. may as well --used REvi intakes are not selling now.
oscd
Old Dec 15, 2007 | 08:34 PM
  #855
shinka213's Avatar
Pettit fangurl <3
spoke to moon tonight
he was in south carolina...in a rain storm...
but doing ok..
Old Dec 15, 2007 | 09:38 PM
  #856
shinka213's Avatar
Pettit fangurl <3
just got off the phone with moon...
its just past "south of the border"
hunkerin down...eatin some grub and gonna take a nap...
still rainin like cats and dogs...
Old Dec 16, 2007 | 12:15 AM
  #857
munche187's Avatar
&quot;MuNcH-E&quot;
For what?
maf VOLTAGE
Old Dec 16, 2007 | 12:17 AM
  #858
Kane's Avatar
Senior Member
You pegged the MAF in a 3.5 in housing???
* Gets ready to be impressed......
Old Dec 16, 2007 | 12:29 AM
  #859
MazdaManiac's Avatar
Originally Posted by munche187
maf VOLTAGE
Uh, no. You didn't.
You are not producing 400+ HP with that blower.
If you are maxing out the MAF reading, its because of the 40% that the flash needs to add the to actual airflow reading to make up for the idle bleed.
Old Dec 16, 2007 | 12:32 AM
  #860
zoom44's Avatar
maf VOLTAGE
then something is drastically wrong
Old Dec 16, 2007 | 12:35 AM
  #861
zoom44's Avatar
ok going to bed so i might be just too tired but pm me or something about what you are saying- it just makes no sense to me.
Old Dec 16, 2007 | 03:41 AM
  #862
Owner of BHR
Several conversations at the same time had me saying "voltage" when, as MM points out, I should have been saying "reading", as in grams/second. Good thing nobody counts on me for serious info around here.
Old Dec 16, 2007 | 09:06 AM
  #863
shinka213's Avatar
Pettit fangurl <3
TMI for this ole fart....
have no clue here!!
Old Dec 16, 2007 | 11:08 AM
  #864
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
OK can someone slow down ether give me a place to go look for what you talking about or explain please. Sounds like you are saying we are running out of current to the MAF.
Old Dec 16, 2007 | 11:16 AM
  #865
Owner of BHR
We are discussing the concept of the airflow demands of the supercharger being more than the MAF sensor can measure. With the smaller intake pipe previously included in the Pettit kit this is more likely to happen. The converse is also true, to a point.
Old Dec 16, 2007 | 11:23 AM
  #866
zoom44's Avatar
the point is that with this kit you should be no where near pegging th eMAF. i ffor someone is that means- to ME- that ther eis a problem.
I didnt understand previously that this kit includes a MAF tube that is smaller than stock diameter. What is the size of the tube that comes with it?
another thing i just read i need confirmation on before i continue.
no one should be pegging this maf before 400some hp
Old Dec 16, 2007 | 11:29 AM
  #867
shinka213's Avatar
Pettit fangurl <3
can someone please explain what "pegging the maf" means?
the only input i have here is that i will be getting a new MAF housing that is a little bigger than what came with the original kit...new housing and new filter..
Old Dec 16, 2007 | 11:32 AM
  #868
Owner of BHR
Think of it this way; measuring the temperature of something that is hotter than the thermometer is calibrated to measure.
Old Dec 16, 2007 | 11:37 AM
  #869
shinka213's Avatar
Pettit fangurl <3
thanks ray...
so what youre saying is that if the housing is too big you wont be able to measure the MAF??
Old Dec 16, 2007 | 11:40 AM
  #870
zoom44's Avatar
maf meters measure the amount of air coming into the engine. they have each have an upper limit they can read based on their design. when you reach that limit its called "pegging the meter". sort of like "pegging the needle" on the speedo or odo= its the limit to the reading it can give.
with a maf if you reach its limit then all of the air above that reaching the motor is going in unmeasured, the electronics dont see it, so not enough fuel is added , you run lean , knock, boom, new engine
the stock Maf in its original 3inch/76 mm housing is capable of measuring enough air to produce 400some hp.
going down in maf tube size while adding FI is never good. you can go up in size. peopel used to go up to 80mm very often but nowadays 90 mm (3.5 inches) is often used.
Old Dec 16, 2007 | 11:44 AM
  #871
shinka213's Avatar
Pettit fangurl <3
thx zoom
Old Dec 16, 2007 | 11:45 AM
  #872
shinka213's Avatar
Pettit fangurl <3
all i can say is that im going thru withdrawal waiting for my ecu...
Old Dec 16, 2007 | 11:46 AM
  #873
olddragger's Avatar
originally Pettit was running its system with a 3 " tube. this was when the INT x or other management systems had to be used. Basically bypassing the maf. Now that there is a flash out and the maf can be fully functional a oem size tube is supplied.
Do I have that correct?
oscd
Old Dec 16, 2007 | 11:57 AM
  #874
shinka213's Avatar
Pettit fangurl <3
oscd
hey OD....this is what i know....the housing that came with the blower (the one you and i have presently) is smalled than the new one thats being used with the flash......i am not sure of the exact measurements....
on my existing housing i have my MAF installed...something moon did for me after the fact when he was up here for rotorfest...i wanted to have my traction control..
moon tells me that the existing housings we have now will not work with the flash..
Old Dec 16, 2007 | 12:07 PM
  #875
Kane's Avatar
Senior Member
That makes sense Shinka - whenever you change the MAF housing you have to rescale the entire ECU - aka retune.
The sensor always reads from 1-5 volts; if your tube size is smaller - 5 volts comes sooner (IE with less airflow). As it gets larger; you will also lose granularity as each volt cahnge is a larger airflow value.
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
