04 Rx8 keeps stalling when A/C is on
Old Sep 22, 2007 | 01:29 PM
Rx804Parz's Avatar
Exclamation 04 Rx8 keeps stalling when A/C is on
Has anyone else had any issues with the 04 Rx8 stalling when the A/C is on?
I have a manual.
It's fine when i'm driving, but once I stop and have the gear in neutral, I can feel the enging bogging down and then the engine just dies and the check engine light comes on; then I have to push the clutch in and try to start the car and it takes awhile to start....close to almost flooding I think b/c the engine is just dying while running.
After it starts again, there is no check engine light.
Any suggestions to fix this will be appreciated.
Old Sep 22, 2007 | 01:39 PM
rodmeister's Avatar
Maybe the idle speed is set too low. I had the same problem with my Toyota and solved it by increasing idle speed. Then again, your A/C might be starting to fail and putting a drag on your engine when engaged.
Old Sep 22, 2007 | 05:11 PM
Jon316G's Avatar
Grasshopper
Ok... list of questions that will help us narrow it down:
1) Roughly how many miles do you have?
2) Has your spark plugs been replaced?
3) Have you had all the recalls performed?
4) Are you running with any mods? If so, what are they? This includes audio, engine management, crank pulleys, intake, etc...
Old Sep 23, 2007 | 01:25 AM
and you cannot adjust the idle speed. duh.
Old Sep 23, 2007 | 08:02 AM
SportCoupe2's Avatar
I would start by changing coils and plugs. I'll bet you see an improvement right away.
Old Sep 23, 2007 | 08:16 AM
mysql101's Avatar
If your coils are going, you'll progressively find that moving from a dead stop to be harder and harder to do smoothly. Eventually, you'll be slipping the clutch at 3,000 rpm in order to get it moving. If you don't, the engine will bog down and you'll stall.
Coils run $26-30 each. You'll need four. Install is extremely easy, but most of the install time is removing misc crap that is in the way (mostly your intake).
Old Sep 23, 2007 | 08:29 AM
stalling is more than likely the engine being low on compression, need to have that checked before anything else
Old Sep 23, 2007 | 08:44 AM
mysql101's Avatar
if he has the original coils, there's a far higher chance of them burning out than the engine dying.
Old Sep 23, 2007 | 11:09 AM
whenever I *unplug* my battery wire, after reconnect it takes about 1-2 drive cycle for my engine to stabilize, yep, the first 1-2 drive cycle stalls ALOT.
After that, it will stabilize
Old Sep 23, 2007 | 08:50 PM
Rx804Parz's Avatar
1) Roughly how many miles do you have? 39,000
2) Has your spark plugs been replaced? No
3) Have you had all the recalls performed? Yes
NO
Old Sep 23, 2007 | 09:47 PM
kennyfrc1's Avatar
Sticking apex seal due to carbon buildup.
Old Sep 25, 2007 | 01:43 AM
With only 39,000 miles on it you're still under warranty. Take it to the dealer with your concerns and let them fix it.
Old Sep 25, 2007 | 11:27 AM
Haze's Avatar
You need new spark plugs. You are overdue. Even if they replaced plugs under the recall, they only do one set. Start with the plugs first.
ladnarf1
Apr 29, 2021 11:53 PM
PotatoCannon
Sep 6, 2015 11:48 AM
Solmors
Aug 21, 2015 10:11 PM
poppinparker
Aug 10, 2015 09:20 AM
mazdaverx7
Jul 21, 2015 07:31 PM
