Radiator light comes on and off
Old Sep 17, 2007 | 10:35 PM
Smoke Honda's Avatar
Mid-Boss
I got the radiator light a couple of times in the last month and I was wondering if my radiator fluid is too low or not. I saw it coming on everytime it's cool outside, about 50 degrees, but goes off immediatly after I start to drive. I changed the oil last week and the mechanic checked off the radiator fluid as good, even though I know that he might have not checked it at all. My car has 26K miles on an 04 and is a manual if that helps. TIA!
Old Sep 17, 2007 | 10:39 PM
dillsrotary's Avatar
jersey fresh
i'd check it yourself, even if you need only an ounce or two to make the light go off.
Old Sep 17, 2007 | 10:54 PM
Mid-Boss
How do I check it? I've never had to deal with the radiator fluid for the 8 before. Thanks
Old Sep 17, 2007 | 11:18 PM
CnnmnSchnpps's Avatar
No means yes
Open your owner's manual. The instructions for checking coolant level are in there... Lots of other useful stuff too ;-)
Oh, and check it while it's cold or you will overfill it.
Old Sep 18, 2007 | 09:07 PM
Mid-Boss
So does the line inside the bottle represent anthing? Because I can't tell how much radiator fluid I have in the car from the outside, it's probraly 1/2 an inch from F to L.
05rx8mazda
Nov 28, 2015 09:42 AM
Vedivan1
Sep 18, 2015 12:39 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
